a k swap isnt a k swap unless you use eg subframe.
if you want clearance. use the ekk2 mounts and eg subframe.
Got the same set up in my car running ekk2 mounts dc2r subframe with k24 and there isn't any problems with abs, might have to modify the headers to clear the abs depending on the headers you run, but in can be done. The power steering pump will just clear the surface material of the bonnet with the frame guttered but will touch on hard launches.
The skunk2 kswap headers clear the abs with no mods
Lower the engine mounts and put spacers in between. Make sure your bolts are nice and long.
