Engine light hunting idle
Hey guys,
Driving into work this morning, everything is good,
pull out to over take this slow horse float, go into second gear, vtec comes on,
starts reving up (vtec on @ 4.5k) at about 5k - 5.5k the car jolts (as in a sudden loss of all power) engine light comes on and obviously i have backed off at this point, i quickly shift up some gears so cruising at 60 in 4th and it seems to be cruising ok, engine light is now just on, there's no weird noises from the engine but I seem to lose power the higher i rev it (without hitting vtec) and also when i stop at lights my idle will sit at 2k or if I've used the gears to stop to get the revs below 2k it'll sit at 1.5 but roam a bit like between 1.5 and 1.6..
Any suggestions, I've got b18c vtir with hondata s200, I would have checked the code but I'm stuck without a serial cable atm sigh, will try get down the shop and fix it but yeah any suggestions would be great.
Thanks in advance!
