Dc2r 4x100 setup problems
Hi guys, recently installed my new setup consisting of
Dc2r calipers
262 knuckles
Redrilled prelude 282 discs
Everyone says you need to run a 3mm spacer between the rotor and knuckle but when I do the rotor and caliper don't line up. With the spacer taken out they line up perfect although there seems to be a slight rubbing sound when I spin the disc. Im pretty sure this rubbing is just the dust cover but cant be 100%. Should I just space out the rotor 3mm and also put 3mm washers between the caliper and the knuckle to solve the problem?
