i removed glove box and only 2 wires i could see is two grey wires which on their other end is a 3 wire connection (2 --> 3 wires)
the connector you are after is a 2 WIRE connector.
Keep looking its there.
trust me ive looked everywhere possible, the only two wires i see running together are ones connected to the three wire connecter, can anyone who has done it on a 96 ek advise please
found the plug, i got
6 ECT - water temperature sensor
sensor need to be replaced??
umm can u help me find mine, what color are the wires, and where abouts is it?
woooohoo found it, 6 SRS (no repeats)...
bloody thing is anoying keeps doing the beeping everytime i goto reds now :(
where can someone obtain the full list of error codes, instead of bothering u guys for explanations?
TDC (top dead centre sensor- 8 flashes?????) hi there does anyone know what sensor this (location) refers too or is this a (noob post) any help appreciated...photo even better-
dont worry found out its built into dizzy........(ignore me)
Any 1 know where can i locate it in a 88 ef7 crx ?
*correct me if wrong*
the ECU is in the same place ( passenger kick panel) or under the passenger seat. The ECU light is located on the ECU , in the centre and will flash a code if needed.
ya wrong benny boy,how dare u not have intricate knowledge of crx's!
ecu for crx gen 2 is in the passenger footwell against the firewall,just pull back the carpet & u'll see it under a gold plate with a little hole in the middle for the ecu light.
