Had a run up of my n360. coming together slowly now.
I will post a video later on today.
hey if anyone knows of any honda n360, n600's up for sale in qld.. no matter condition could you let me please know?! so keen on one now after owning a few honda's and seeing a hayabusa swapped one on youtube.
wow! i almost pulled the trigger on those TN7s myself when i saw them pop up on perth gumtree.
i just didnt have the space to store them unfortunately =(
look forward to your prgress mate!
You guys still going with these restorations? I have a TN360 III (http://www.ozhonda.com/forum/showthr...bought-a-Honda...)
I stripped the motor, all good, just needs a hone and valve grind.
BUT... crown wheel is missing 3 teeth.
Hoping someone has an extra gearbox/diff lying around and can help me out...?
I don't know if they are the same donk as the n360 but suspect they are. Any help would be awesome.
Hehehe I am.
Do tell.
Hi chez. I haven't checked this site for quite a while. I've been playing around with N360's for yonks. Can't help you with the gear tho. How did you go with other parts?
I'm looking for a crankshaft. The suction screen on the oil pump is VERY fine mesh, so fine that mine blocked up with crap from the cam chain guides, idler etc and with no oil pressure warning it eventually developed a knock in a big end bearing.
So if anyone has a used N360 or TN360 crankshaft I'd be interested. They can be swapped between models with a minor mod.
By the way, the engines are not the same but a lot of the internal are.
Hey Freddy,
Yeah I've got myself a replacement gear set including crown wheel. I also got a crank and rod assembly as mine was shot, and a fuel tank.
Just gotta finish off my other project before I open this can of worms!
Cheers.
Ha well that's sweet mate. Where'd you find the crank? Know of another anywhere?
Hmmm I may have a contact, I thought I was lucky getting a crank though! I'll let you know...
Yes the oil pressure issue is a bit of a worry - I'll look into running an idiot light I think.
For interest's sake, this n360 looks extremely tidy. Bit pricy but would be an excellent base for a minter.
http://www.ebay.com.au/itm/RARE-retr...gId=5336652905
Yeah I've seen that. I already have a good one, just looking for a crank for the spare donk.
http://i875.photobucket.com/albums/a...ps610044cf.jpg
