CL9 - MIL then VSA
Hi,
MIL pop'ed up over the weekend, obd scanned today and found the igniton coil was broken, the mechanic put in new part with new spark plugs as well.
MIL is now gone but VSA appeared, we tried to scan again but nothing came up, which is a bit strange?
Will probably bring to another scan at different place, but anyone came across this before? Did a bit a research most people saying it can be app sensor, hopefully is not, did bring for a short drive, it felt ok to me...
i recently changed a brake light switch in a CL9 that had its VSA light on intermittently.
Maybe check if your brake lights are working properly. If not, the brake light switch is easy to replace just above the foot brake pedal.
When the mechanic changed your ignition coils and spark plugs, i assume they changed all 4 for each.
