Uneven wear on new brake pads
Cause: After fitting new brake pads, customer came back for a check up and we found huge uneven pad wear.
Solution: Uneven pad wear is often a caliper problem, caused by faulty seals, sticking or bent slide pins. Overhaul the calipers on that axle. Ensure you have used the correct lubricant, such as Bendix Ceramasil Brake Parts Lubricant on the right component
Follow Bendix Brakes on Facebook HERE.
To learn more about the Bendix Brakes range of products visit: www.bendix.com.au
