Hi guys,
What are you're experiences/reviews with these 2 IM's and what do you reccommend on a DC2?
Hi guys,
sk2 is dc2r copy.
edelbrock is performance.
mild NA to stock motor turbo stock rev range - go skunk
reving to 9-10k, higher boost ie 15psi + built motor or a hypo NA go the victor x
skunk will be more responsive and more mid, power till 8.5-9k, the victor x will have less mid but will allow you to breathe 9k+ rpm
simple as that!
skunk2 is better to compare to PerformerX isn't it?
i got the edelbrock on my car its sick
does anyone know how the the Skunk2 manifolds go on the Vtir's?
As I said before, Skunk2 manifolds are pretty much a copy of the Type R manifold.
Using a Skunk manifold on a VtiR will bring the stock throttle body from the lower vtir position up to the higher type R position.
so edelbrock is better for high NA revs & boosted apps while skunk2 is for the normal bolt ons for complete NA... right?
Then has any1 used both on these on the same engine? Pros n Cons?
