okay ,,so the b20 head is not going to get me anywhere even if i work it out as in porting,,valves, guides,,springs etc
always do :)
B20 head isn't worth all that work just hold out until you get a vtec head. On firesport someone's selling a b18cr/c7 head for 1.5k nego if you're interested B18c head with buddyclub valves, TODA valve springs and titanium portflow retainers. all brand new parts with a second hand port and polished head. does not include cams.
if you're not changing the pistons it may be wise to run a B18C2 head with a skim, should get you close to 10:1. 9.2:1 is a bit low imo.
Run skunk2/blox intake manifold if you want it to be similar to an ITR head. I think you'd benefit from the compression increase more than having slightly better flow.
i see
Are you planning on freshening up the bottom block or are you just gonna slap the vtec head on ? If you're gonna freshen it up run the RS ITR pistons 11.5:1 ( CHR1S's recommendation :) ) Not too bad in price and they have similar characteristics to Oem ITR ones. Then that way you can go for a b18 head. High comp ftw.
B18c head with buddyclub valves, TODA valve springs and titanium portflow retainers. all brand new parts with a second hand port and polished head. does not include cams Price:$1500 neg
what do you think on that
Honestly that's not bad considering everything is basically done for you, he is nego on prices so try throw him a offer. If you're gonna be turboing it then the RS machines are not for you sonce theyre cast style pistons. You're looking to go down the forge route onviously which will set you back a bit more ... All comes down to what your future plans are really. Yeah of course NA's need high comp, but in the end most of your power is from the head. Get a nice set of cams to go with that b18c head like skunk2, toda or m22x cams ( another one of chr1s's recommendations :) ) and you should be producing satisfying numbers after the tune
