i dont think you want to wait for that, my b18c died, if i had of sold it off first i would of had 5k to start off...instead i had to fork out more cash in one hit for the k
k series just picks up and goes, gear after gear it doesnt disaapoint.
My B20 feels like it has more torque thooo? i guess its due to the heavy duty clutch and mine almost on its way out ?
Well everything is for sale for the right price. But I'm still building the car! Will be slow for awhile, times are tough around xmas/ny. Asking for opinions in my build thread atm before i go forward with few things! But yeah same goes for us, we aint baller or anything just save by diy and learn on the way. I'm a student after all so don't work often either.
haha man you must have to save up cash something epic if you can buy all that awesome stuff while studying! been following both your builds, inspiring stuff man. good on you for DIY'ing everything. I reckon you should keep that teg man, sooo much work put into it so it'd be a shame to see it go so soon :(
something broke on mine today
finally turned over the k20, worked fine thank god
Another day... another set back.
This one is our fault though. As you all know, we took the K20 out last week, and had it sitting on the ground, then we discovered the threaded head on the K24... so we started pulling that apart, disregarding the K20 all together.
Today we started by pulling the gearbox off the K20... boom... clutch is dead. Glenn confirmed that on side had no meat left on it, and the other had about 1mm. Glenn has told me to ring Direct Clutch in Brisbane and have them repuck the Excedy clutch I have with either a 5 or 6 puck carbotic spring disk. I'll also have them test clamp the pressure plate and see if they can modify the fingers for more clamping pressure. Obviously I'll have my 3.8kg Toda flywheel machined in the process. Hopefully this can all be done before Thursday (We'll be dropping it off on Monday)
So we decided to put the K24 all back together, ready for the gearbox to be mounted, so that we can put it into the car by no later then Friday! It's all going to be very touch and go for us and this build in the next week. The basic run down is:
- New clutch (To above specs) and machined flywheel
- Fit Clutch and flywheel
- Fit engine
- Rewire engine
- Fit sub frame
Hopefully the above can be done by next Friday. The following needs to be done on the Saturday morning :s
- Wheel alignment
- 3' stainless cat back
As most of the work shops in Brisbane are only open till 12pm on a Saturday, I'm not sure how I'm going to go with the Saturday morning stuff... even though the exhaust shop I plan to use is only down the road from my suspension shop.
If all of the above is done, I'll be getting Adrian to tune the car on Monday... YAY!
Anyway... where are some happy snaps of the car. I always love to see engines with all the bits attached to them, so I thought I would mount my Toda headers and my RBC to the engine, just so I can see what it all looks like... before it's hidden in the engine bay.
http://i4.photobucket.com/albums/y12...a/IMAG0192.jpg
http://i4.photobucket.com/albums/y12...a/IMAG0193.jpg
http://i4.photobucket.com/albums/y12...a/IMAG0194.jpg
http://i4.photobucket.com/albums/y12...a/IMAG0195.jpg
I've also noticed that when I get bad news about the engine (Such as the threaded spark plug and clutch), I start to clean stuff. I've basically degreased the gearbox last week when I found out about the spark plug... and the engine when I heard about the clutch.
This has really got me to thinking of getting rid of aircon, sourcing an electronic steering rack (Thus eliminating the powering steering pump), and going all out with a wire tuck. I'm actually REALLY enjoying all this DIY work I've been doing/helping with, and I wouldn't mind actually building a car to similar specs to something you would probably find in the States.
I took mine to all japan day in silverwater park today. go here to see the pics I took of the cars there:
http://www.ozhonda.com/forum/showthr...l-Call!/page27
probably got some members rides in there somewhere :)
Robi's post just pwns all!
Paint Prep! Just another day when its off the road....
http://i839.photobucket.com/albums/z...g?t=1321444515
restored my type r seat foam. now for a big clean and they should be as good as new :)
