territory turbo
territory turbo
My gen 2 had plenty of go.
Just rem the engine is designed with low end torque. If you got the accord k24 you will loose that
Whoa hang on
CRV
K24A1
Found in:
2002-2006 Honda CR-V, Element
Compression: 9.6:1
Power: 160 hp (120 kW) @ 6000 rpm
Torque: 162 lb·ft (220 N·m) @ 5200 rpm
Rev limit: 7000 rpm
Accord Euro
K24A2
Found in:
2004-2008 Acura TSX, JDM CL9 Accord Type-S, RB1 Odyssey Absolute
Displacement: 2,354 cc (143.6 cu in)
Power: 200 PS (150 kW; 200 hp) @ 6800 rpm
Torque: 232 N·m (171 lb·ft) @ 4500 rpm (166 lbft @ 4500 rpm U.S.)
The euro makes more torque & earlier than the crv engine
Don't know what you're on about :S
Maybe he meant the adm accord euro...
K24A3[edit]
Found in:
2003-2007 Honda Accord (Europe) and Japan (JDM) and 2003-2007 Honda Accord Euro CL9 (Australia, New Zealand)
Bore and Stroke: 87 mm x 99 mm (3.43 x 3.90 inches)
Compression: 10.5:1
Power: 189 hp (140 kW) @ 6800 rpm
Torque: 164.5 lb·ft (223;N·m) @ 4500 rpm
VTEC Engagement: 6000 rpm
Redline: 7200 rpm
In saying this limbo, don't get me wrong the crv moves and is fine for everyday driving around town but last weekend I drove home to sydney from Wollongong and on some of those hills she struggled abit..
Unfortunately adding 20kw to the swap - not including at the wheels
Will not feel like much especiially when the crv weighs a **** ton
It's just not the right car
Now putting a J35 from the '08 accord
3.5 litre v6 with over 330nm - that'll get you going
our a3 is closer to the a2, wikipedia has it wrong
just perform a K24A2 + K20A head conversion with Kpro V3 and just the usual bolt ons, then your cooking with oil!
this is my long shot goal for my RB1 .. which is about the same spec as the CRV ... but looks better :)
Mmmm dat odyssey!!!!!!!
