If it is in between when the engine is cold, then it is fine. If you are worried, carry the spare oil in your boot.Quote:
thanx.
Btw the OIL FILTER WAS A BIATCH AND A 3/4!
when i took the old one out oil started spilling all over my clothes, my arm even my hair. Damn that was messy!
then to top it off i had trouble screwing the new one back in.
Is that normal? Oil spilling out when u take the oil filter out?
cheers
Any differences if the car has oil cooler installed?
hehe yeah you should drain the oil before removing the filter, or at least remove some of the oil.Quote:
yeah they are a biatch to change sometimes. I couldnt get my filter off the first time I changed it, got a mech to do it. Ever since then ive screwed the new one on with only my fingers to minimize excess torque (tightness), so its easier to remove next time.
They dont make much difference during normal street use, its really only useful on the race track when ur engine is revving hard.Quote:
Originally Posted by spoondc2
Quote:
Originally Posted by EuroDude
i did drain the oil man.
But it was on the jacks. Maybe it didnt drain all of it while the front being tilted up.
hmm
also i noticed the first time i started it, bits of oil spurted out of the exhaust.
is this normal?
cheers
Oh sorry, i mean oil change if there is a oil cooler installed....Quote:
:p
There will always be oil in the filter no matter what, but not a large amount. Not much u can do about it really except be ready for the spillage and place a container under the filter/sump area.Quote:
Oil came out of the exhaust? That doesnt sound right :o
yeh like bits of little spots hitting the garage door.
saw it happen in both my mates cars with big fart cans before also. Btw the civic also has a fart on on it :P
but yeh didnt really pay much attention as it seems to happen with big mufflers.
Dunno really... should i be worried?
cheers
Well it can be a sign of overfilling the oil. Did you check the dipstick oil level? If you overfill the oil, the oil can find its way into various parts of the engine its not supposed to be in, and come out of the exhaust.
Worn piston rings is another sign of oil exiting throught the exhaust.
nah the oil level is fine, its between the two holes in the dipstick.
The engine is probably just showing its age.
cheers
LOL, its not oil, its dirty water comong out the exhaust.
Our cars burn C8H10(Petorl) and O2(oxy) and produce H20 (water) and CO2(carbon dioxide) , also coz the burn isnt perfect u get some C (carbon) and CO (caron monoxide).
N e ways, this water usually leaves ur exhaust as steam, thus u never notice it. But, if you start ur cr cold, ur exhaust pipes are cold, and this steam condenses as water droplets in ur carbon covered piped, the rest of the gasses soon push out all this water, hence the black droplets on ur garage wall.
