It's actually a virtual machine with Windows in Russian preloaded with the EPC. So will need
vmware player to use it.
The reason it's setup this way is because the software licence activation is locked down to this virtual machine.
Haha all good Kevin~ : )
it's good to have handy. Smash repairers won't have the excuse that they can't find parts.
This may sound like a strange question, but how many kms do you guys think the rubber on an ep3 clutch pedal would last before it wears out?
I only ask because I had a look at a car on the weekend with very low kays but the clutch pedal rubber was completely worn through. Should I be suspicious?
Hey guys,
I put my 235/45/17 semi's on today and the rear is scrubbing...I used a mallet and heatgun and rolled the rear guards asmuch as I could so they were nearly flat against the inside of the guard however the rear still scrubs. I'm running Aragosta Coilovers dropped around 1.5-2inches all around. I even stiffened up my ridiculously hard coilovers all the way and it still scrubs.
Alignment for rear:
Camber: -2.62 and -2.34 LH/RH respectively
What else could I do to stop it from scrubbing?> I was thinking about rasing the rear 5mm-10mm and see if it stops rubbing. I am going to a trackday on monday and really don't want it to chew through my new semis :(
Also it's mainly the right hand side that's scrubbing the left isn't scrubbing as much...Unforunately I don't have adjustable camber arms either..Not that you would want more than 2.3-.5 of camber anyway.
How are you getting that much camber without adjustable camber arms in the rear?
