yeah nepolian so that means CAMBER FTL ! :p
I stand my statement......cause if want a car like ours and is worried about fuel consumption and tyre wear etc......
You probably bought the wrong car!
Phil! You can sit the front wheel pretty close to the guards (less than 1 finger gap). I have 17x7.5 +30 with 1.2 deg camber and it doesn't rub!
Supersteve....you've seen it!
My ep3 has been making some sort of rattling noise for the past week or two.
i tried to listen to where the sound was coming from and it seemed like from under the car where the headers sit. so i jacked up the car and the sound was stronger ontop, then underneath. The sound is coming from the pulley area, where on the chain there are brown marks, i'm assuming it is the water pump leaking. Has anyone had this problem? How can i fix this??
thanks guys :)
are the brown marks stained on ur bonnet aswell from underneath the bonnet not on top
Nah no stains underneath the bonnet, just on the inside part of the chain.. (not sure if its normal)
check ur driver side engine mount for cracks. I think ur engine mount has cracked and the liquid has squirt out. Just a thought i could b 99.99% wrong (NOTE: i mostly fail in life)
