does anyone know what code 68 is?
hey ecu man, great info!
just put a jdm type r p73 ecu into my b18c block / type r head. comming up with a code 23 - knock sensor, and a code 20 - eletrical load detector.
the knock sensor isnt a drama, just have to resolder the two internal wires back to its base, but i have no idea where the eletrical load detector is, or how to fix it.
any help is much apreciated. Thanks
ELD exists in the bottom of the main under hood fuse box.Its a current transformer that informs the ecu of the total elec load being drawn by the car.Quote:
Originally Posted by spardikis
I dont have one in my crx,so i didnt hook it up to the ecu,& i still get code 20 all the time but CEL does not stay on.
ECU-MAN reckons no adverse effects from this set up,& i dont seem to be having any,but only done 90kms so far.....
yeah dude
dont worry about the ELD
it will be ok
also im about to get a hondata and tune. the s200 unit. should i worry about fixing the knock sensor? or do these units not utilies them?
thanks again guys :) :)
you should be able to disable it with hondata
aaaaaaaaarhhhhhhhh i cant find it in my EM1, there is a brown plug plugged into a black box that says GME Relay or somthing, other then that there is not a green plug with 2 pin connector :(!!!!! i even pulled out my glove box just to look for it ffs :(
EDIT: uness its behind all the aircon shit then im really :(
Is this a stock VTiR with stock ecu?Quote:
Originally Posted by Micko
Usually a blue 2 pin plug clipped into a green holder with another 3,4 or 5 pin plug next to it.Usually directly below the passenger air vent.
If your really desperate just cut the SCS wire coming out of ecu
C7 on OBD2a(plugs on ecu seperated by a space)
A10 on OBD2b(plugs all side by side)
extend it to a switch & run a ground wire to other pole of switch,& switch on instead of having to short a connector.
SCS is usually a brown wire(sometimes with a stripe) trace it from ecu to find the connector.
yes it is Stock ECU/Stock Car CRXer, thank you for the information... i know what plug your talking about its just not on the left side of the passenger foot wall so i will check near the centre console.. i shall have a look later today and get back to you,.
hey guyz, was tryng to do the ecu test yesterday but had no luck in finding the green holder with 2 blue plugs, all i found was 2 blue plugs hanging loose but didnt have the brown and green wire, but instead one plug has 2 wires black and brown and the other had 3wires light blue, brown and pink. would the blue plug with black and brown be the one im looking for? if it is..
just wondering why would it be hangin loose and could i still use it to perform the ecu test, or are my plugs just located in a completely different location,
thanx
its the plug with 2 wires on it. Use this guide the same way....Quote:
Originally Posted by khOa`
so use that plug for the test?? kool thanx
