[CL9] Accord Euro Navigation Splash Screen modification program
Following from the work of Bysin, I Created a small program in Labview to change the splash Screen on the CL9 Euros. It works fine with my v12 disc haven't been able to test on others.
Program can be found below
I've created an exe for everyone to use, but I can't upload it as an attachment either (it in zip format and 37kB).
Anyone know what I need to do?
Green block gangster
Array
I can host the exe for you. if your interested please pm me and ill send you my email address,
Ill post it here for all to download
Hopefully the exe will be posted soon, so are the Instructions:
Instructions:
-Copy LOADING.KWI from original navigation DVD to C:\some location\
-Run AU_BMP_Mod.exe
-Browse to “Original Bootloader File” (C:\some location\LOADING.KWI)
-If using V12 disc “Search Type” = “Quick”, Not sure what will happen with other versions
-Browse to “New Bitmap”. Note file format
-Hit “Modify”
-Hit “Exit”
-Create a CD/DVD with original root directory files from original navigation DVD, replacing LOADING.KWI with C:\some location\LOADING.KWI
-Insert into Navigation unit
-Start the car, and hold Set Up, Menu, and Cancel for 5 seconds.
-Hit the "Version" button on the touch screen
-Hit the "Load Disc" button on the Version screen.
-Navigation Unit will load the new firmware and reboot
-Take out your burned CD/DVD and put back the original navigation DVD
Need your help
Hi,
I have a Accord euro CL7 2004 model (japaneese used and imported), i change the battery recently and now the standard DVD, CD, navigation touch screen controls are not working and i don't have a setup DVD.... please let me know where to download the DVD or if you can send me the files....
If needed mail me on rajithw@yahoo.com
Thanx, infra
wow CL7, Are you in Australia?
Nope i'm in Sri Lanka and it's difficult to find the nav dvd since local dealer doesn't import this model... pls help
hey....
Hey, quite interested in your invention and want t try out in CL7 (Hope it will work) would you please send me the exe created by you.... if you can e-mail it on rajithw@yahoo.com or let me know a if you have hosted it somewhere. Thanks
Instructions:
-Run AU_BMP_Mod.exe
-Hit “Modify”
-Hit “Exit”
-Start the car, and hold Map/Guide, Menu, and Cancel for 5 seconds.
Hi mate can you mail me the EXE please. my mail is niven@orange.mu
Please help me
This is taking a while....
