Page 2 of 2 FirstFirst 12
Results 13 to 18 of 18
    Mar 2007
    www.letusdrive.com.au
    D15B7 YOOOOOO!
    will be doing this in a few weeks including removing the piston inside the rack! cheers dorikon
    Check out my build thread EGB16T. http://www.ozhonda.com/forum/showthr...build../page14
    Check out my for sale thread constantly updated with b series/ eg parts!
    Wakefield Honda Nationals First Timer : na-118 EG b16 1:16.4900
    Sep 2006
    Out in Nature
    91 eg5 b16a
    Is that the notorious bitch pin?
    Quote Originally Posted by beeza View Post
    Gotcha,and do U knock/bash/bend that washer into the grooves before U tighten it right up and that locks it in?
    First you position the washer in the 2 grooves of the steering rack.
    Then tighten the rack end down. And then you can stake the Lock Washer with a Roll Pin Punch (pic below) to lock it in.
    Quote Originally Posted by na-118 View Post
    I'm guessing you're converting the rack to Non-Power Steering. Make sure you remove the Piston Seal Ring and O-Ring.
    I remember reading someones build thread that went into a lot of detail on converting your rack to non-p/s but I can't remember who it was now..
    No dude, bitch pin is the spring pin that locks the shift rod into the transmission.
  4. #16
    Mar 2007
    D15B7 YOOOOOO!
    yeah' that's in my intention dorikon. i've read up this morning basically removing the piston and the seals and assemble it back together
    apparently you gota cut the piston off on hondatech
  5. #17
    Sep 2006
    Out in Nature
    91 eg5 b16a
    Thanks mate,great stuff!
    RePPed!
  6. #18
    Yeh that's right if you wanna go all the way, cut the piston off.
    Here's Mattski_VTIR's build thread with very nicely detailed pics
    http://www.ozhonda.com/forum/showthr...=1#post3041154
