bump steer adjustment?
I have done the upper control arm swap and whiteline caster kit install. many sites say the upper control arm sway introduces more bump steer. Now i have looked into bump steer and what it is exactly and some good info was found on good ol wikipedia.
Bump Steer is the term for the tendency of a wheel to steer as it moves upwards into jounce. On modern cars the front wheels toe out as the suspension is raised. This gives roll understeer. The rear suspension is usually set up to minimise bump steer, where possible.
A typical value is two degrees per metre, or perhaps more, for the front wheels.
Excessive bump steer increases tire wear and makes the vehicle more difficult to handle on rough roads.
The linearity of the bump steer curve is important. If it is not straight then the length of the tie rod needs to be adjusted.
Bump steer can be made more toe out in jounce by lifting the rack or dropping the outer tie rod, if the rack is in front of the axle. The reverse applies if the rack is behind the axle. Usually only small adjustments (say 3mm) are required.
so i am aware that this increased rear tilt on the knuckle lowers the tie rod end and is the cause to the increased bump steer. is there anyway to lift it back up and reduce bump steer? washers could maybe be used to lift the tie rod end up but then would make it impossible to get the locking pin in with the castle bolt.
i have yet to experience bad times of bump steer but would like to reduce it if possible.
thanks
Is this the end of my car modding days? Buying a house says so...
OK, the suspension designer will typically try very hard to introduce substantial amounts of understeer by all sorts of means. With the stock caster angles you most probably have some intentional bump steer that causes the wheels to gain toe-out in bump / jounce / compression, as a means to induce a tendency toward some degree of roll understeer. The designer doesn't really want the bump steer per se (and will try to minimise this), but does want the roll understeer tendency that comes with the bump steer.
This will be achieved by mounting the steering rack 'too low', and / or positioning the tie rod end 'too high', and / or by making the tie rods 'too short'.
The bump steer is caused by the disparity between the arc in which the tie rod end moves, and the arc in which the upright / knuckle moves (or more accurately, the arc of a point having a fixed relationship to the knuckle that occupies the same location as the centre of the tie rod end ball).
If the caster angle is increased then the end of the steering arm / tie rod end is lowered and the tie rod will become angled more downward toward it's outer end. Now, as the suspension moves upward in bump the arc of tie rod end motion will be more lateral (i.e. the lateral component of tie rod end arc motion will be increased to some degree relative to with the lesser caster angle), and this will create some tendency to toe-in with bump motion (i.e. the opposite effect to what the suspension designer intended, which may or may not be a good thing...).
Assumimng that the OE bump steer is to toe-out (in bump motion, which also may or may not mean to toe-in with droop motion); it's likely that increasing caster as you've done will decrease the factory toe change and thus reduce any existing intentional bump steer. It's also possible that lowering the tie rod end far enough might move things past zero bump steer into actual bump toe-in and thus toward roll oversteer (the opposite of the designer's intention).
I hope that makes sense, it's not easy to describe without diagrams...
You can make a simple bump steer guage with two pieces of plywood, a couple of hinges and some pointers (screws will do). Cut some plywood so that it's a bit wider than the wheel rim diameter, and cut again so one piece is a bit taller than the hub centre (e.g. if the rim is say 15" diameter and 300mm radius, then make one piece of plywood say 16" X 320mm, and the other piece 16" X about 300mm or whatever). Now hinge the two pieces together along the 16" sides so you have two 'pages' that can open and shut.
Shut the 'pages' and place the 'book' flat on the ground near a front wheel with the hinges near the tyre. Now open the 'book' so that one page leans gainst the rim. You now need to make some pointers that can rest against the leading and trailing edges of the rim at more or less hub centre height, screwing screws right through the ply works well (screws will be near the corners of the vertical ply sheet / 'page').
Position the bump steer guage (pages open at roughly 90°) with the front and rear pointers touching the rim, now place some substantial weight on the other 'page' to prevent it moving. You can now jack the chassis up and down while noting the change in toe as measured by the pointers touching / losing contact with the rim (one pointer will always touch the rim, but it may need to be 'helped' a bit, especially if the hinges are not frictionless).
The vertical 'page' of the guage will move in / out pivotting on the hinges while maintaining the original toe measurement, so any toe change change with suspension motion (i.e. bump steer) can be seen as a gap appearing between one of the pointers and the rim. Removing the springs will be required to make this measurement possible in bump motion.
I'm still digesting it all John, but ...
Ozhonda's resident McGuiver.
Nick.
I doubt you'll need these but 'J's Racing' & 'M Factory' make some 'roll centre adjusters' to suit the Eg/Ek knuckle.
How much of a drop are you considering?
Given the popularity of "slamming" Honda's, I think it would be a common issue if there was a problem.
By moving the tie rod further up from where it's supposed to be with washers, the forces (torsional moment) increase dramatically.
Tread carefully grasshopper.
I believe there are inverted tie rods for the newer strut front suspensions, but this doesn't help you.
Nick.
Nick.
If you can find a copy of 'How To make Your Car Handle' by Fred Puhn, you'll find a description and pics of the plywood bump steer guage (I think it's that book, I 'lent' my copy to someone so I can't double check).
'Roll centre adjusters' aren't intended to fix bump steer problems, but rather to restore (in some degree) the OE suspension geometry that is messed up by substantial lowering (i.e. by changing of the wishbone angles). They may well have some affect on bump steer, but it would be luck if it were the affect you wanted.
"Slamming" doesn't alter the caster angle, which is the mod responsible for the bump steer. This is because as the upright / knuckle is leant backward the end of the steering arm lowers, thus changing the 'horizontal' angle of the tie rod (which is what can create additional bump steer).
Don't walk there at all. The tie rod end is attached to the steering arm with a tapered fitting. It's not possible to shim it higher with spacers, the male and female tapers have to be fully seated / inserted or else you will have a dangerously weak connection.
Taper fittings are almost universal in ball joint and tie rod end attachment, but there are a few that use a straight shanked fittings (and this works perfectly well). For the life of me I can't see why taper fittings are so common with ball joints etc, they are a pain to seperate if they have been overtightened, even by only a small amount (and most mechanics overtighten them).
i have no bump steer problems at all after gaining 5 degrees caster with both the whiteline shim kit and upper wish bone swap in my eg.
i've taken my car for a few hot laps of mt cootha both clockwise and anti clockwise and it was fine. this is a smoother road tho so i took it up to the waterfall at Springbrook down the coast which is not smooth at all, and in a few sections painful (missus very sore ribs can vouge for that) and it had no problems with keeping the line i choose, understeering, wandering, or front end sudden loss of traction.
the car just felt more direct with road with more push back to centre in the wheel for an over all more go kart like ride, which i enjoyed.
I'd say JohnL that your on the ball with the reversed some of the engineered bump steer. i cannot feel any bump steer, tho i am not fully aware of how to diagnose it as it has never been an issue that has popped up in the past.
my car is only low not super low or even dumped.
I have 6° caster on my CB7 Accord (2° - 3° stock), and like it very much for the reasons you stated. I've also deleted the PS belt, and like that very much as well, though the steering can load up quite a lot in some corners and parking is a pain.
With bump steer, most cars will have at least some, and some changes to geometry will make it either better or worse, or make a change not great enough to feel.
In my last post I said something that could be read as meaning that a substantial lowering won't cause bump steer, which wasn't my meaning. Substantially lowering the chassis can often (but not always) result in significantly increased bump steer because it changes the orientation of the arc in which the tie rod end moves. This is another reason to avoid substantial lowering.
If you are also making other changes that could affect bump steer (e.g. increasing caster), then you could possibly end up with positive and negative affects partially cancelling each other out, but equally could have cumulative affects resulting in substantial bump steer.
post from Soichiro's way@MF on honda tech
"rollcenter adjusters will not have much of an impact on bumpsteer. This is because the knuckle and upper control arms will stay in their relative positions- providing that the ride height is set to the same level as before installing the "rca" kit. "
i've read nothing bad about these only great comments. definately something i am going to look into down the track when i get height adjustable coilovers. my bump steer is not a problem but i am very keen on these roll centre adjusters. my car isn't really low but i understand the RC and CG concept in relation to body roll and agree with what they do. i don't know the geometry tho which would be interesting to see.
Originally Posted by 55EXX
...but i understand the RC and CG concept in relation to body roll...
Very few people really do understand this stuff. Roll theory (or rather, weight transfer theory, because roll is only a symptom of weight transfer, not a cause) is very complex and hard to get your head around. What you read in the popular suspension books etc is only the tip of the iceburg, is sometimes wrong, and even when correct tends to be so simplistic as to be misleading.
I've been investigating roll theory for years, and I only understand it to a limited degree (the more I know the more confused I get...). It's the source of much debate and disagreement between proffessional suspension engineers, but is really at the core of chassis dynamics...
i only have a basic understanding from what i have read in mags and on the net. but the thing is does moving the rc higher to meet with the cg increase roll stiffness? or change it some other way? increasing roll stiffness can easily be done with sways or spring rates what is the advantage of the roll center adjusters then beside smoother ride. sharper turn in higher corner speed etc can be had with bigger front sways too.
Interesting I didnt find that post =/ I found something different, oh well sorry for the misleading, RC are great and Im definatly looking into them myself
