Here's my Cluster Conversion Wiring Chart to enable people doing cluster conversions in Honda Civic ED, EG, EH, and EK, and CRV models.
It covers
Col.1 - EG (1992 - 1995 Honda Civic) - wiring info sourced from US Workshop Manual and checked against a JDM EG6 cluster.
Col.2 - CRV (1997 - 2000 Honda CRV) - wiring info sourced from US Workshop Manual and checked against a locally obtained 1999 CRV cluster, purchased from Honbits. This is the unit I am using in the ED Hatch rebuild.
Col.3 - ED6 (1991 Honda Civic) - wiring info originally sourced online and from US Workshop Manual but discarded due to number of irregularities. The pin designations printed here have been checked against a current ED6 cluster, originally in my ED Hatch. All pins have been verified from the traces on the back of the cluster. Totally different to the info published in the US Manual.
Col.4 - EK (Civic) - wiring info from the web (MarkLamond), but adjusted to fix a couple of mistakes. The EK cluster is very similar to the CRV cluster in pin designation and colour-coding.
Hope this is useful for people doing cluster swaps.
DISCLAIMER: I have carefully compiled this info and double-checked it, but I cannot accept any responsibility for any damage you may cause to your vehicle as a result of using this info. Remember: check everything yourself before making any connections permanent. The Test Light and Multimeter are your friend!
If you use this info successfully, or you find an irregularity, please let me know, and I will check it and make changes to the chart (if necessary).
Peter
