where can yo get accord euro supercharge kit from?
hi there im from NZ and was wondering if you can get supercharge kits from aussie? ive seen some pics on the internet and they make kits for them but for acura tsx
That's right but not from Aust.The problem you'll have is engine management.Maybe the K pro works with the supercharger.
the kit i saw it had everything even the computer to go with it and thanks for your reply
There isn't a supercharger kit with an ECU to go with it. There is only the supercharger kit with a reflash to work with your stock ECU. That reflash is only for the TSX. You can get the kit, and add your own kpro and DC5R ECU to enable tuning.
You can also get it from ebay. I am quite sure your ECU won't accept the reflash that they list there (even if it did, you have to mail your ecu, immobiliser and keys to the US), so you will need a kpro and dc5r ecu with patch harness from Hondata.
is it possible to run the supercharger kit without tunning the ECU? I know to tune it properly for max the output. but just to get it run and boost, is it possible?
then would it be possible to run the TSX ecu with the reflash for S/C and run it in conjunction with the stock ecu?
