Yo dude, check your engine number, i've notice most Accords 4th gen 90-93 model have the f22a9 engine code. When you try look up specifications for that engine its pretty hard to find, i only saw one site but its in some kinda language, im guessing its euro spec.
This is a translation of the site above from some dude who said it was in polish.......
"the charts on the page basically indicate if the engine was carburated or with injectors and if it used unleaded gas. It also said that the F22A9 engine was only used in the 2.2L engines outside of europe and since i doubt there is an accord with an A9 engine here in USA it had to be imported form Japan. So it is a good bet that you could be sporting the 150HP powerplant i also found out that after a full reset of the of the computer the engine doesn't go above 6300RPM but after few kilometers of driving the ECU learns the new injection maps and will go untill 7300-7500RPM. And also the powerband of the engine starts at 4500RPM and goes on to the mid 7000
Thats about it for the engine part. the rest just explains the different trims and their differences like tails, bumpers etc.
Hope this helped out "
