Hey guys just want to confirm and pls correct me if im wrong
Make sure your car is at cool temp and basically open the radiator cap and the coolant bottle
1. drain the coolant out from the radiator (the tap just underneath the car)
2. flush it with running water
3. make sure you close the coolant tap afterwards .
4. make sure the a/c temp is on the red mark (heater)
5. refill it with new coolant put the coolant on max in the coolant expansion bottle.
6. and fill up the radiator with coolant Honda spec / Correct spec for the Euro.
7. open the radiator cap let the engine breath + coolant bottle and start up the car and let it run for couple of minutes.
8. top it up if necessary. n close the rad cap
9. Done
