Page 1 of 4 1 2 3 4 LastLast
Results 1 to 12 of 47
Thread: BLOX Racing
    Newcomer Shift Performance is an unknown quantity at this point
    Dec 2008
    12/252 Hume Highway Lansv
    EG-EV0 8-S15
    BLOX Racing
    Shift Performance Parts are proud to announce that we are the Australian
    BLOX Racing authorized Dealer
    At the moment we are working with BLOX Racing USA to bring you the latest and exiting NEW range (not listed on the BLOX website yet)of performance products that BLOX Racing have to offer.
    We are fully backed by BLOX racing in the USA and can get any support needed for all of there products. And all the BLOX Racing Products we sell will also be used on our EG Circuit/Track car.
    The following parts are available to order thru us now.
    Camshafts
    • Chill-cast cores
    • Precision CNC-machined
    • Tuner Series – standard lobe designs
    • Competition Series – wider primary and secondary lobe designs
    • Semi-blank cores also available
    • Optimizes horsepower and torque
    • For maximum results, use with BLOX Racing valve train components
    Cam Seals
    • Billet aluminum construction
    • Anodized for durability
    • Three O-rings for maximum protection against oil leaks
    • Recommended when servicing or replacing camshafts
    Valves
    • Forged EV8 stainless steel
    • Black nitride coating for superior wear protection
    • Increases compression
    Valve Springs
    • Made from chrome silicone alloy wire
    • Provides maximum lift
    • Prevents valve float
    • Ideal for naturally-aspirated or forced-induction engines
    • Highly recommended for aftermarket camshafts
    Ti Retainers
    • CNC-machined titanium
    • Reduces overall weight of valve train area
    Helps ensure proper spring heights and pressures
    Intake Manifolds
    • OEM quality casting, machining
    • Improves engine’s overall flow characteristics
    • Balanced, tuned for peak power
    • Accepts factory sensors, aftermarket oversized throttle bodies
    Best maximum results, use with BLOX Racing billet throttle bodies
    Throttle Bodies
    • Billet AL6061
    • Provides quicker response, smoother operation
    • Direct-fit replacement
    • Accepts factory sensors, throttle cable
    Block Guards
    • CNC-machined AL6061
    • Strengthens, supports upper cylinder walls
    • Minimizes head gasket failure, cracked cylinder sleeves
    Perfect for forced-induction engines
    Turbo Manifolds
    • 3.5mm thick runners, reduces overall weight
    • Central wastegate bung
    • Lifetime warranty against cracks
    Universal Mufflers
    • T-304 stainless steel, TIG-welded
    • 102mm tip
    • 60.5mm and 76.2mm
    Universal Race Mufflers
    • Extremely lightweight
    • Replaceable muffler insert
    • 2.5” and 3.0”
    B-SERIES EXHAUST HEADERS
    Applications
    • All B-series engines
    • Certain motor swap applications may require modifications
    General Product Benefits
    • 4-2-2-1 Tri-Y header design
    • 2-piece; spring-hinges
    • SUS304 stainless steel construction
    • TIG-welded seams
    • Internally TIG-welded head flange
    • 1.5mm wall thickness
    • 10mm head flange thickness
    • 8mm exhaust flange thickness
    • 2.5” exhaust collector
    Technical Specifications
    Hi-Flo Header
    • Recommended for displacement 1.6L - 1.9L
    • Piping sizes
    o 1.6” - 40.6mm
    o 1.8” - 45.7mm
    o 2.0” – 50.8mm
    o 2.5” - 65mm
    Max-Flo Header
    • Recommended for high compression 1.8L and displacement 2.0L – 2.2L
    • Piping sizes
    o 1.8” - 45.7mm
    o 2.0” – 50.8mm
    o 2.2” – 55.9mm
    o 2.5” - 65mm
    MAP Bypass Valves
    • Blocks boost from reaching MAP sensor
    • No check-engine light
    • Protects MAP sensor
    TYPE-A 1990-UP NSX; 92-00 CIVIC; 94-00 INTEGRA; 94-UP ACCORD
    97-01 PRELUDE; 1999-UP S2000; 00-UP ACCORD V6;
    TYPE-B 88-91 CIVIC, CRX; 90-93 INTEGRA; 90-93 ACCORD; 91-96 PRELUDE
    TYPE-C 2001-UP CIVIC; 2002-2006 RSX
    TYPE-D 95-99 ECLIPSE, DODGE NEON 420A
    FMU
    • Increases fuel pressure as manifold pressure increases
    • Provides additional fuel needed for safe operation
    • Recalibration / rebuild kits also available separately
    UNIVERSAL FMU
    4:1
    6:1
    8:1
    10:1
    12:1
    FPR’s
    • Properly tune air / fuel ratio
    • Works with factory or aftermarket fuel rails
    • Universal application
    www.shiftperformance.com.au
    12/252 Hume Highway,Lansvale NSW 2166
    PH:02 9728 9654
    FAX:02 9728 9653
    Dec 2008
    EG-EV0 8-S15
    Front Camber Kits
    • Replaces front upper control arms
    • Fine tune camber settings, reduce wear
    • Quick, easy adjustments
    • + / - 4 degrees
    ACURA 94-01 INTEGRA
    HONDA 92-00 CIVIC, DEL SOL
    Lower Control Arms
    • Forged AL6061
    • Replaces factory pieces
    • Extremely strong, lightweight
    • Helps accommodate wider wheel, tires
    ACURA 90-01 INTEGRA
    HONDA 88-00 CIVIC, CRX, DEL SOL
    FULL-BODIED COIL OVER SUSPENSION
    • Tuner Series: BXSS-00100
    • Front: 10 kg/mm (559 lbs/in)
    • Rear: 8 kg/mm (447 lbs/in)
    • Competition Series: BXSS-00101
    • Front: 12 kg/mm (671 lbs/in)
    • Rear: 10 kg/mm (559 lbs/in)
    • Drag Pro Series: BXSS-00102
    • Rear: 18 kg/mm (1,006 lbs/in)
    • Package Contents
    • 4 full-bodied coilovers
    • Spanner wrench
    • Shim/spacer kit (for 1996-2000 Honda Civic EK)
    • Current Applications:
    • 1992-1995 Honda Civic; 1994-2001 Acura Integra
    • 1996-2000 Honda Civic
    • Product Highlights
    • Coil springs are CNC-wound using SAE 9254 steel
    • Mono-tube shock design (non-adjustable)
    • 46mm piston, 20mm shaft
    • FINA shock oil, high pressure Nitrogen gas
    • Height adjustment range: up to 4”
    METERING GAUGES
    Gauges
    • 52mm, green backlight
    • Highly visible, clear markings
    • Adapters, gauge pods, and replacement parts sold separately
    BOOST
    EGT (EXHAUST GAS TEMPERATURE)
    FUEL PRESSURE – LIQUID FILLED
    OIL PRESSURE
    OIL TEMPERATURE
    RPM (TACHOMETER)
    VACUUM
    VOLTAGE
    WATER TEMPERATURE
    Gauge Adapters
    Oil filter block adapter: For oil temperature or oil pressure gauge
    Water temperature sensor adapter: For water temperature gauge
    Banjo bolt adapter: For fuel pressure gauge
    Vacuum Manifold Kits
    • Billet AL6061
    • Six vacuum ports, 1/8” NPT
    • Additional sources for vacuum requirements
    Extended Wheel Studs
    • High strength alloy steel
    • Meets safety requirements
    • 12 x 1.25 and 12 x 1.5
    • For maximum results, use with BLOX Racing forged lug nuts
    Short Shifters
    • Provides smooth, precise shifting
    • For maximum results, use with BLOX Racing billet shift knob
    SINGLE-BEND 88-00 CIVIC, CRX, DEL SOL; 90-93 INTEGRA
    DUAL-BEND 94-01 INTEGRA
    Billet Shift Knobs
    • CNC-machined from steel
    • Weighted to approx. 450 grams
    • Increases quick-shifting effects
    • For maximum results, use with BLOX Racing short shifter
    • 10 x 1.5
    Radiator Stays
    • CNC-machined from high grade aluminum
    ACURA 94-01 INTEGRA
    HONDA 96-00 CIVIC; 99-UP S2000
    Oil relocation kits
    Oil Caps
    PH:02 9728 9654
    FAX:02 9728 9653
    Member doonbar is an unknown quantity at this point
    Nov 2005
    ACT
    Integra DC2
    price for Hi-Flo B series header?
    ...LS...
    Dec 2008
    EG-EV0 8-S15
    PM sent
    PH:02 9728 9654
    FAX:02 9728 9653
    Member MrJohn has made a few knowledgable posts
    Jan 2009
    SYDNEY
    YA!HONDA!
    be good to have some prices on there heheh
    how much for the
    Universal Mufflers
    • 102mm tip
    • 60.5mm and 76.2mm
    EG4>CBR250RR>EM1>GOLF>AP1
    Dec 2008
    EG-EV0 8-S15
    pm sent
    PH:02 9728 9654
    FAX:02 9728 9653
    Member jdmlvn has made a few knowledgable posts
    Jul 2005
    South West Syd
    ek <3
    price for blox oil cap pls.
  8. #8
    Dec 2008
    EG-EV0 8-S15
    pm sent
    PH:02 9728 9654
    FAX:02 9728 9653
  9. #9
    Newcomer andy9999 is an unknown quantity at this point
    Dec 2005
    brisbane
    EJ8
    hey price for throttle body for b series?
    thnx
  10. #10
    Dec 2008
    EG-EV0 8-S15
    PM sent
    PH:02 9728 9654
    FAX:02 9728 9653
  11. #11
    Ozhonda Supporter VT-11-RR has made a few knowledgable posts
    Dec 2008
    Bankstown
    N/A is best
    pm price for short shifter for EM1.
    are they single or dual bent?
    thanks
    No Comment
  12. #12
    Dec 2008
    EG-EV0 8-S15
    pm sent
    PH:02 9728 9654
    FAX:02 9728 9653
