DOHC shifter bushing
EK / DC2 Type R rear sway bar bushing kit
EK/EG rear sway bar end link
EK/EG front sway bar end link
S2000 half shaft spacer kit
EG/EK/DC2/EF/DA spherical bearing rear trailing arm bush kit
EG/DC2/DC2R B series engine mount kit
EK B series engine mount kit
DC5R / EP3R engine mount kit
DC2R/EG6 rear lca
Accord Euro CL7/9 Rear camber and toe kit
Accord Euro CL7/9 Rear camber kit
EG/EK Super tie rod ends
DC5 rear trailing arm bushings
EK front camber kit
EG front compliance bushing
Hardrace products listings
EG Civic / EK civic / DC2 integra / EF civic / EF CRX
-EG /EK / DC2 Super Tie Rod End ( Upside Down Installation ) $225
-EG Civic Complete Bushing kit $365
-EK Civic Complete Bushing kit $365
-DC2 Integra Complete Bushing kit $365
-EG/DC2 Front Camber kit $245/pair
-EG/DC2 Front Camber kit in Spherical Bearing $375 / pair
-EK Front Camber kit in Spherical Bearing $375 / pair
-EF civic / EF crx Front Camber kit ( Discontinued item) We still got a few left $325 each pair.
-EK Front Camber Kit $245/pair
-EG/EK/DC2/EF rear camber kit $125/pair
-EG/EK/DC2/EF rear camber kit ( Spherical Bearing ) $235 / pair
-EG/EK/DC2/DC2 Front Roll Center Adjuster $175 pair
-EG/EK/DC2 Rear trailing arm bushing $115/pair
-EG/EK/DC2 DOHC shifter bushing kit $55
-EG/EK/DC2 Type R rear sway bar bushing kit $45
-EG/EK/DC2 Type R front sway bar bushing kit $45
-EK rear lower control arm bushing $120
-EG6/DC2r rear lower control arm bushing $75
-EK front sway bar end links ( 1 pair ) $75
-EG / DC2 front sway bar end links ( 1 pair ) $75
-EK rear sway bar end links ( 1 pair ) $75
-EG/DC2 rear sway bar end links ( 1 pair ) $75
-EG front sway bar end links ( 1 pair ) $75
-EG / DC2 / DC2R B series engine mount kit ( 5 pieces kit ) $365
-EK B series engine mount kit ( 5 pieces kit ) $365
-DC2R/EG6 rear lower control arm ( OEM control arm with hardrace bushings ) $195 per pair
-DC2/EG front lower control arm ( OEM control arm with hardrace bushings ) $215 per pair
-DC2/EG front lower control arm ( OEM control arm with hardrace pillow ball ) $345 per pair
-DC2/EG Steering rack bushings $75
-EG/EK/DC2 Rear trailing arm bushing ( Spherical bearing type ) $345/pair
DC5R integra / EP3R civic
-DC5R/EP3R engine mount kit ( 4 pieces kit ) $465
-DC5R/EP3R rear camber kit $165
-DC5R Front Roll Center Adjuster $195
-EP3R Front Roll Center Adjuster $195
-DC5R rear trailing arm bush $195
-DC5R front lower arm bushing $135
-DC5R front sway bar end links $75
-DC5R rear lower arm (rubber) $195
-DC5R rear lower arm ( pillow ball ) $245
-DC5R rear knuckle bushings ( 6pcs kit) $195
S2000
-S2000 Half Shaft Spacer kit $195
-S2000 Engine mount and transmission mount kit $395
-S2000 Rear Diff mount kit $250
-S2000 Front Diff mount kit $225
-S2000 Front Anti bump steer kit $135
-S2000 Front RCA $295
-S2000 Rear RCA $235
-S2000 Rear toe control arm ( 2 piece per set ) $210
Accord Euro CL7/9
-cl9/7 Accord Euro adjustable rear camber / toe kit $345
-cl9/7 Accord Euro adjustable front camber kit $345
-cl9/7 Accord Euro adjustable rear camber kit $165
-cl9/7 Accord Euro RCA $225
-cl9/7 Accord Euro front lower arm bushing 6pcs $175
FD civic
-FD civic adjustable rear camber kit $295
GD Jazz
-GD Jazz engine mount kit $450
Hardrace Website :http://www.hard-race.com.au/
Hardness is 150% higher than OE rubber bushings.
