Results 1 to 10 of 10
    Newcomer Array
    Jan 2007
    Sydney
    Civic Vti
    Anyone heard of a "wind booster"???
    I was scoping through Singapore ebay and found this for a civic FD
    http://cgi.ebay.com.sg/Wind-Booster-...3D10%26ps%3D63
    I'm quite sceptical about the potential (if any) performance output of the "Wind Booster."
    Has anyone bought one of these before??
    Feb 2009
    dayyyyyuuummmm
    thatsafrenchassnameyvonne
    They work. Buddyclub have a similar product. Both work the same, though it's not called a 'wind booster'.
    With newer hondas and the "drive by Wire', the throttle response is a little laggy. The above product just works on minimising the 'lag' and initiates acceleration instantaneously as though the car operated with a throttle cable.
    '99 Integra GSi (gone)
    '95 Integra Vti-r (drag-spec)
    '91 Cressida Grande (daily)
    MT Drag Radials, Injen CAI (dc2r) & various parts for sale:
    http://www.ozhonda.com/forum/showthread.php?t=112491
    This is just a device that intercepts and alters the signal from the accelerator pedal to the throttle body control unit - very much like a Piggback ECU that intercepts signal to the fuel injectors.
    I have friends who removed these things after installation because they caused a number of drivability issues.
    MFactory Competition Products
    Ninja turtle Array
    May 2004
    Sydney
    Chloe
    We had a short discussion on this in the Euro section. In short, don't waste your money.
    http://www.ozhonda.com/forum/showthr...rottle+booster
    Stocky CL9 - 1:17.2
    /thread closed
    Sep 2008
    Melbourne
    FD1 Civic
    I was actually interested in the buddyclub sprint booster because the pedal setup on the civic is not so good for heel and toe .. but not sure whether its worth it
    Dec 2008
    835 Beaufort St
    hondie 2000
    don't buy. rip off, it amplifies the signal from your pedal...
    so if u press the pedal @ 50%, the ecu will recieve 70% (etc.)
    if u press @100%, the ecu will still register 100% (cos it can't do more).
    total waste.
  8. #8
    Don't waste your time/money.
    If you are thinking the pedal seems a little laggy, have you checked to see if the cable is indeed loose? You should be able to tighten it up.
  9. #9
    Ninja turtle Array
    May 2004
    Sydney
    Chloe
    Quote Originally Posted by EKhatchguy View Post
    The FD Civic has an electronic throttle. Honda's programming makes it a little laggy.
    Stocky CL9 - 1:17.2
  10. #10
    Dec 2008
    835 Beaufort St
    hondie 2000
    ^it's for emissions, os that you don't send unburnt fuel through the cat. prolongs the cat's life.
