Page 92 of 109 FirstFirst ... 428289909192939495102 ... LastLast
Results 1,093 to 1,104 of 1300
  1. #1093
    Aug 2008
    gladesville
    DA9-N/A DC2-S/C
    As long as the swap is no bigger than 15% in capacity. There will be no hassles.
  2. #1094
    Sep 2008
    civic EK9
    Hi guys, I brought a b20vtec from a member here a months ago now. Okay here's my story I'm getting my car tune (car still at the dyno) we have been having problem with my car, when the engine is hot the car backfire and Also ill be running 3 cylinder for like 2-3sec then it stop and comeback to 4 cylinder. We change the dizzy, spark plug wire, change ecu, change TB. Still doesn't solve the problem.. What could the problem be?? I just want the car to run good and don't miss cylinder. If any of you guys experience this before please share your thought. Cheers
  3. #1095
    Nov 2009
    klungemobile
    Quote Originally Posted by CTR_EK9 View Post
    Is there anything wrong with the injectors?
    We're doing it for the children.
  4. #1096
    Sep 2008
    civic EK9
    Quote Originally Posted by newpaddy3 View Post
    Nope the injector are good. But the spark plug leads is old and kinda dirty. The car was running on msd dizzy but somehow that dizzy ain't in good condition so we changed to my stock dizzy, is there such thing as (timing the dizzy?)
  5. #1097
    Moderator Array
    Apr 2008
    '90 EF8/'94 EH9
    yeah you just rotate it?
  6. #1098
    Moderator Array
    Apr 2008
    '90 EF8/'94 EH9
    I know it's elementary but did you check/change the actual plugs?
  7. #1099
    Sep 2008
    civic EK9
    Quote Originally Posted by dougie_504 View Post
    Well the dizzy from my old car I haven't change or touch ever since I brought the car, 8-9 months ago so yeah... I've done some reading on the net and most of the people recommended to change/check your spark plug wire. Will it be okay to drive it now? Cheers guys
  8. #1100
    Oct 2006
    P1.5 460F/350R
    Ctrek9 you should open new thread for your engine issues. Even though it's b20vtec, it's technical issue not a discussion abt building b20vtec
  9. #1101
    Sep 2008
    civic EK9
    Fair enough. Will do cheers mate
  10. #1102
    Mar 2008
    under a bridge
    Jdm EG6
    take it to a reputable mechanic if this one is just shotgunning it and replacing everything, how is it running on 3 cylinders? no spark or no fuel? if theres no spaark u will smell the fuel, if its the injector try using a noid light to check individual injectors, also check if the ecu is throwing any codes or even better, try uning a scanner and showing some live data
    hmm id tap it. Even in mid air like that. Possibly with the pee pee flying out too.
    you guys remember squirtqueen.com ? I spent many a hr in computer studies in yr 10 looking that up.
  11. #1103
    Mar 2012
    ST.ALBANS
    EK4
    Hey guys, anyone here from Melbourne that has actually had or gone through a b20vtec? If so could you guys please help me. I'm contemplating on doing a b20 vtec swap into my ek4. Just want to know if their are any reputable b20 vtec builders & tuners in this area. If someone could get back to me via pm it'll be much appreciated.
  12. #1104
    Moderator Array
    Apr 2008
    '90 EF8/'94 EH9
    For Melbourne I would hit up Josh @ Sleeping Performance
