how would you kno if this was happening? just want to be prepared for it incase it happens to me
Mine had a slight flat spot just of idle mainly noticeable on take off from a set of lights.I had this for a few months then 1 day the check engine and vsa lights came on.Computer was reset and all was good.This lasted over 3 weeks.The APP sensor was then replaced.As i said before HA replaced it under good will.
Mine was more severe, car shunts violently... and then no power even when throttle is depressed all the way down... this is when i knew it was screwed.. lol... turn off the engine and turned it back on and it worked for a bit and same thing happened... got worse and worse as i left it unattended... eventually happened every 5 mins...
