Results 1 to 12 of 13
    Jun 2005
    99 EKC7
    S80 gearbox question
    hi huys, well ive got a 2000 B18C7 setup in my 99 cxi and ive noticed the gearbox is starting to get a bit sloppy in gear changes (feals loose and ever so slight random crunching through some gears.
    I was thinking of refreshing the box (syncros, bearings, seals and bushes) but i was also thinking of changing final drive too. to help with torque and 1/4 mile runs. but its the final drive is where im getting confused.
    i know the JDM S80 is 4:7 but as for the aud ive been told both 4:4 and 4:7,
    and b4 ppl say search, all i could find is jdm spec.
    So can anyone please clarify the specs on the aud S80 and also would 4:9 be too short for daily driver with regular strip work too.. mind you i do get on the highway as well...
    thanks heaps guys.
    All DC2 integra gearbox is S80
    GSI 4.2fd
    Vtir 4.4fd
    type r b18c7 4.7fd lsd (N3E)
    type r 96 spec 4.4fd lsd
    type r 98 spec 4.7fd lsd (N3E)
    difference with 98 spec and 96 spec is
    1.Final drive
    2.98 spec has a longer 4th & 5th gear
    i was thinking of doing the same upgrade, i reckon its better to have a 98 spec gearbox and upgrading it to 4.9 so ur daily and highway driving will still be ok.
    since 96 box 4th and 5th gear is shorter, upgrading to 4.9.. forget about driving on the freeway
    Jun 2005
    99 EKC7
    SO with mine being out of a 2000 itr, will a 4:9 be too short for the highway?
    if u got 2000 itr then im pretty sure u got the 4.7fd already in it. 4.9fd should be a good upgrade
    Oct 2004
    Sydney - Cabramatta/Liver
    Jazz EVO IX
    if box is crunching try changing the oil first. Some nice fresh oil helps at times.
    agree with above, you've got a 4.7 if its the ITR s80 from a 2000 model.
    I think a 4.9 will be short for a daily driver. Ask Benson, i beleive he had a 4.9FD in his eg
    Evo IX - THE FINAL EVOLUTION
    Jun 2005
    99 EKC7
    ive found that its only started to crunch ever since the thrust or thrw out bearing had started to make the whining noise.. and im confident that it has something to do with the bearing.. the noise only accours at hight revs and when i put the clutch in or throw the box into nutral if i push down on the clutch the noise goes away....i had alook at the shifter bushing and yes they are shot.. so upgrade next week hopefully..
    Oct 2004
    Jazz EVO IX
    sounds though like the input thrust bearing may be screw and not releasing properly.
    Better get that sorted so it doesn't ruin the box further
    Jun 2005
    99 EKC7
    Thats the next plan.. just sorted out the tailing arm bushes.....
    Dec 2005
    Point Cook, VIC
    EK1 CXI
    if it feels sloppy and sometimes crunches, check ur shifter bushes....
    Jun 2005
    99 EKC7
    Quote Originally Posted by IEVAQ8 View Post
    yeah, they are on there way..
    May 2005
    a honda i guess...
    is there an actual way to test what final drive u have? i was told that you put your car in 4th gear and drive at 100kmh and your revs will tell you what final drive you have. somebody confirm?
    _____________________________________________
