+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 12 of 13
    Low Idle Rev - Honda Civic
    Hey guys,
    I own a 99 Honda Civic. At the moment, I just recently noticed it after a friend pointed it out, but it seems that while my car is on and idle (brake or handbrake on), the car is sitting on 500 revs. My friend pointed out that when the car is idle, it should be sitting at 1000.
    Is that true, and if it is meant to be sitting on 1000, how do I fix this?
    Cheers
    daaaaaaaaaaaaaaaaayyyyyyyyyyyuuuuuuuuuuuuuuuuuummm mmmmmmmm
    i was always under the impression that revving 500-700rpm in idle was fine, my eg idles around 600rpm. correct me if i'm wrong.
    Member vinnY is a splendid one to behold vinnY is a splendid one to behold vinnY is a splendid one to behold vinnY is a splendid one to behold vinnY is a splendid one to behold vinnY is a splendid one to behold vinnY is a splendid one to behold vinnY is a splendid one to behold
    Feb 2006
    sydney yo
    green whip!
    check under your bonnet, there should be a sticker with the rpm range it should be at idle
    Member beeza has a reputation beyond repute beeza has a reputation beyond repute beeza has a reputation beyond repute beeza has a reputation beyond repute beeza has a reputation beyond repute beeza has a reputation beyond repute beeza has a reputation beyond repute beeza has a reputation beyond repute beeza has a reputation beyond repute beeza has a reputation beyond repute beeza has a reputation beyond repute
    Sep 2006
    Rainbow Region
    Slammed EKSedan
    Simply turn the idle/air adjust screw until it's where U want it.
    My car is and auto,so I set it with it in drive as if I was at a set of lights.It says 900,I like it at 1,100rpm when in D.In N it's 1,500-1,600.
    This is where mine is on the d16y4,on the throttle body:
    reset the ECU afterwards and ya done!
    Member Chriskoss has made a few knowledgable posts
    Mar 2009
    Shitnee
    2 Door EK GLi
    500 seems a little low.. 600-700 I thought is normal
    Is the idle also fluctuations (going up and down between revs)? Or just sittin flat at 500.. if you'd like to advance the timing a little better.. then you can unbolt the distributor and move it a little clockwise or anti clockwise til you hear the engine idle you need and also have a friend looking at the tacho
    cheers
    Member Gio has made a significant amount of informative posts Gio has made a significant amount of informative posts Gio has made a significant amount of informative posts Gio has made a significant amount of informative posts
    Nov 2007
    In the pit
    A black one
    SEARCH. While your there search how to search properly. This has been covered in the last fortnight.
    Anyone selling a black ek1 facelift Hood (OEM)?? PM ME
    Yeah it kinda fluctuates.
    When i start up the car...initially it'll sit on 1000 revs...and then slowly slowly, it'll progress down and sit on 500 revs....
    I dno if its a bad thing. Oh and my car is manual too....
    Sorry if its a repeat of a previous thread guys...
  8. #8
    Feb 2006
    sydney yo
    green whip!
    gio if you're gonna flame about searching at least find the magical thread you speak of
    in other news, on cold the iacv usually lets more air in to help it get up to operating temp quicker
    as it reaches operating temp it'll settle down a few hundred
    like i said run out an check under your bonnet before adjusting anything, may or may not be within range for all you know
  9. #9
  10. #10
  11. #11
    Just checked under the bonnet. Theres no recommendations for what the idle rev should be on there....
  12. #12
    my prelude has a label under the hood: 750 +- 50 rpm. my 98 civic gli is the same.
