DIY : Heat-shield over Pod Filter with cold air feed
DISCLAIMER: The following is provided as a GUIDE ONLY, and neither myself nor Ozhonda take any responsibility for the outcomes of someone else doing the following. You follow these steps at your own risk!
AIM: Install a DIY Heat-shield (over Pod filter) with a cold air feed, and get PQ points while I’m at it!
REQUIRED: Screw driver, Socket wrench set, Aluminum sheet and Superr-Flex vent ducts (can get these from Bunnings), CF wrap vinyl (PEP’s auto)
What’s wrong with this set-up?
1. DEFECT because of the uncovered Pod filter.
2. The heat inside the engine bay gets sucked into your intake.
SOLUTION:
PART 1: HEAT-SHIELD
1. Remove old intake setup
2. Measure where you want to mount your Heat-shield.
3. Get your aluminum sheet, cut it to shape, then connect to each mounting points.
4. And for those who prefer to have a CF look…
(to be continued...)
