i have a feeling it'll be the same dimensions as stock but valved higher to handle springs with higher spring rates
Do you have any idea what the stock spring rate would be I have been told that the pedders springs are 20% stronger then stock so what would that make it?
i ran skunk2 sport shocks with skunk2 lowering springs for 18 months , they were firmer and are shorter than oem i thought they were great for the price you paywork well for everyday driving and for occasional 'spirited' although i found using a harder spring or the adjsutable sleeve coil worked better with them, im currently now running the skunk2 pro s....
Regular off the shelf 8041-SPORT are OEM replacement, same size. The 8041-RACE is shortened, but I'm not sure you can get them new in Australia. Shock length affects shock travel (inevitably less) and the static shaft position. Ride height is determined by where the spring perch is on the shock. If a shorter shock has a lower spring perch, then you'll be lower, but if you have a height adjustable perch then it's moot.
