Ok so the clutch in my euro is playing up. I've done a search but can't find anything that relates. While driving the car the clutch looses pressure as if there is a leak somewhere and air is getting in. It always changes depending how I am driving. Such as on the highway just cruising at 110 the clutch will loose heaps of pressure and will become hard too select gears. After a bit of normal driving and use of the clutch it becomes better but not 100% still.
I have had the clutch slave cylinder changed, since is had a bit of a leak, and had the clutch bled (which the mechanic found no leaks) but still I have the problem. What else could it be? Master cylinder seems too be fine with no leaks.
Any help would be great. Thanks
