Hey guys,
Basically as topic asks. No spark from plugs when i crank my engine. I believe its a obd2 dizzy and i have matched it to the obd1 loomb. ie I cut the obd1 plug off the old dizzy and soldered it to the new dizzy. However i im having trouble determineing weather the problem is due to a incorrect wiring polarity or some sort of failure with the ignition coil / ignitor.
Would like some advice on trouble shooting as why i have no spark and how i can sort this out through some method of elimination? I have narrowed it down to three circuits (stated below) that are wired into the Distributor. Are these circuits / sensors polarity conscious ? eg if i have the correct circuits wired up to the correct pin on the plug... but one might be reverse polarity? will this be a problem etc
Crank Position Output
TDC Output
CYP Output
Which of these circuits wire to the ignitor?
For reference for others in the future here is some info i have compiled
