Results 1 to 8 of 8
    Jul 2009
    Mango Of The Hills
    EG8
    Removing shifter leaver from gearbox
    hey guys, just wondering how do I remove shifter leaver from gearbox?? not sure whats its called but theres like a hollow split cylinder thing holding it to the box..
    Iv tryed hitting it out and it hasnt moved at all, heat did nothing.
    Iv attached pics of what I mean, its the thing circled in red
    Attachment 17559Attachment 17560
    Why don't you tell your daddy to comb his damn hair, look like some spiders is having a meetin' on his head.
    Sep 2007
    Melbourne
    EG4
    keep hitting. get the correct sized punch and keep hitting. wd40 helps to a certain point.
    that's why its called the b*tch pin LOL
    Jul 2009
    Mango Of The Hills
    EG8
    How hard is it to reuse it/ put in replacement gbox?
    I don't have a punch lol, but will find a bigish Philips head driver and see how I go
    you need a 8mm FLAT punch.
    Hold it dead straight onto the split pin - a few whacks and it will slowly work its way out
    NOTE when the pin is just about to pop out , TAP it out dont WHACK. If you whack it the pin will often sproing off somewhere and you might lose it
    Jul 2009
    Mango Of The Hills
    EG8
    Thanks for that ben . Anything else I can use instead of a punch?
    Jul 2009
    Mango Of The Hills
    EG8
    Thanks boys, put some WD40 on it and a old Philips head driver I had that fitted awesomly to it and yea when it was almost out, I locked some vice grips to it. Thanks again boys
    Quote Originally Posted by xclusive_eg8 View Post
    some 12mm headed oem honda bolts will actually suit it fine.
  8. #8
    Newcomer Array
    Oct 2010
    ermington/sydney
    eg civic turbo
    try a nail thats what did mine,keep an open mind!!!!
