Page 1 of 2 12 LastLast
Results 1 to 12 of 13
    Jan 2010
    PnP Garage
    BREEZE
    How do I fit an Ultra Racing Front Strut Bar in my DC2?
    Hey guys,
    I've just bought an Ultra Racing 2 Point front strut bar, and I intend on putting it on once I get my coilovers...
    Anyway, my question for those who have done it before is how did you get around mounting the bar? Both strut towers have wiring looms and the lefthand side has all of the air-con tubing running across it right where the bar mounts.
    How do I move these? Has anyone done it before?
    This picture shows what I mean
    part time potato
    Jun 2006
    Brisbane
    K20 DC2R
    drivers side should be fine, passanger side unbolt the bracket that holds the ac line on the front side of the shock tower, its just to the right of the arrows tip, and bend the line out of the way just enough to fit the strut brace. also helps to manouver the brace on if u jack the car up and drop the shocks
    Jan 2008
    Australia
    eg5
    Left side, pry the wire/electric plugs holder with a screw driver, or you could undo it and relocate it lower, right side do as above, undo 10mm bolt that holds the a/c line and just push it outta the way.
    pic should help abit
    http://img96.imageshack.us/img96/1149/21102010333.jpg
    Dec 2009
    Sydney
    K20 nugget
    Thanks heaps guys! Got a brace myself and was wondering how I was going to do this!
    wow, youve really thrashed the integra! (chuckles)
    DEEFUFF 4LYF
    Jan 2010
    PnP Garage
    BREEZE
    Thanks Killa and Duzy... Rep for you
    With the wiring looms, where did you move them to?
    part time potato
    Jan 2010
    PnP Garage
    BREEZE
    Thanks, but still doesnt really help
    I'll sort it out, can't be too hard. Just a matter of finding a place to put the looms.
    part time potato
  9. #9
    Jan 2008
    Australia
    eg5
    what i did was just pry it out with a screw driver, bend the metal brackets outwards
  10. #10
    Jan 2010
    PnP Garage
    BREEZE
    Where did you re-mount them?
    part time potato
  11. #11
    Jan 2008
    Australia
    eg5
    It still sits in the same position, i just bent all the wiring/brackets outwards to fit my carbing one
  12. #12
    Jun 2006
    WA
    EG+CL9
    remove the metal wiring harness's completely and use cable ties to tuck the wiring up behind the strut towers (and under battery)
    remove the bracket holding on the a/c line, wrap the a/c line with some 5mm black foam padding (so brace wont rub on metal), install brace and remount the a/c line to the strut tower around the brace (might require a little force)
    heres one i prepared earlier ...
    D15b Turbo EG Sedan Build + CL9 Lux N/A Build
    http://www.ozhonda.com/forum/showthread.php?t=127680
