Results 1 to 3 of 3
    This Time the Sunroof
    (Slowly working through each component of this damn car......)
    The sunroof recently stopped working.
    The open and close relays both click when I toggle the sunroof switch, so I assume both switch and relays are okay.
    The 3 under-dash and under-bonnet sunroof fuses seem okay.
    A 2-pin plug with a green/yellow and green/red wire connects to the sunroof motor. I assume these swap as +ve and –ve depending on whether the button is set to open or close. However, I cannot get any voltage reading from these wires.
    Any suggestions of a likely source of the problem.
    Thank you
    Newcomer Array
    Jun 2008
    sumwhere
    97 lude
    game over.
    Apr 2006
    Sydney
    ej coupe
    if you aren't getting a voltage at motor wires, then it's probably a faulty relay.... dirty or corroded contacts. should probably test your fuses also with a meter
