Results 1 to 5 of 5
    Oct 2010
    '03 Euro [CL9]
    Question [CL9] Grounding wire kit install help
    Folks,
    Just got myself a HKS 5 point grounding wire kit yestoday, but I'm a bit puzzled on where to put them, the length I have are:
    75cm
    60cm
    55cm
    40cm
    35cm
    Now I've got no clue where to connect them, The HKS kit has no manual, and my Pivot Raizin kit has no clear guide either.
    Can some one give me a noob/dummy guide on where exactly to connect them like the pic down below? (which is a very concise guide for the 02 accord)
    http://s.lowyat.net/uploads//attach-...1288970863.jpg
    2003 CL9 5AT *ECU REFLASHED*
    Oct 2010
    '03 Euro [CL9]
    *UPDATE* decided to go ahead anyway by myself and see how I go.
    So far I've done 2 wires
    1. Negative Terminal to existing Ground on battery side (passenger side) of car, effectively double the width of existing ground wire.
    2. Engine Block to Negative Battery terminal (a bolt from the cam cover to battery terminal)
    So far it does f*** all. but then again I still have a few vital parts to wire:
    * Throttle body (the bolt is too ^&&*ing tight)
    * Alternator (bolt too %^&*ing tight)
    When I was "trying" to unbolt the alternator, I found there is another factory grounding wire on the Drivers side, next to the alternator... it's completely deteriorated (it's %^&*ed, the rubber cover is completely gone and all the rest of it. Im yet to figure out what to do with that.
    Apprantly there should be a wire running from the battery to the tranny... How the F am I meant to do that on a auto CL9? then theres the tight beyond all hell alternator and Throttle body bolts....
    Feb 2012
    Accord Euro CL9
    Hmmm, I'm not sure if I've done mine right, but this is what mine looks like.
    Oct 2010
    '03 Euro [CL9]
    You've done it right.
    Feb 2012
    Accord Euro CL9
    Haha, hopefully. Haven't felt any changes except that I haven't seen the HVAC/Audio display backlight flicker anymore. At least not yet. Lol.
