Results 1 to 7 of 7
    May 2011
    EJ8 - SOHC Vtec
    Ej8 - D16Y8 - No power under 3000rpm after mechanical sevice
    I just had a major car service
    all new belts, water pump, oil filter, spark plugs, radiator flush, oil, fuel filter.
    Although now the car seems to have a flat spot under 3000rpm, and then it has a more noticable increase.
    What did the bugger do to my car!? I've heard other people relate this issue to the MAF sensor, some suggest disconnecting it to see if it fixes.
    1-3k revs just feels the same, only the engine is making more noise.
    any ideas?
    Nov 2009
    Civic EJ8
    D and B series dont run MAF lol.... too cheap to have em
    If the car feels sluggish, might be the oil used, what oil did u use?
    could be that they didnt adjust the ignition timing as well
    I <3 BOOST! D16+T SOHC
    May 2010
    Cabramatta,NSW
    DB6
    added a vtec controller for you and set it at 3000k rpm HAHAHA
    Nov 2010
    Some where in the world
    b18c2+T Ej8
    Maybe he missed a teeth when putting timing belt back, should check the timing again, Also maybe he used Thicker oil.
    Oct 2006
    Hunter Valley NSW
    lownslowsedan
    take it back and get them to sort it out.
    Nov 2009
    Civic EJ8
    Quote Originally Posted by trism View Post
    Yup, if anything, the car shoulda felt better, not worse as described
    May 2011
    EJ8 - SOHC Vtec
    yeh thanks guys, best thing is just to take it back. Just hate dealing with mechanics, they never want to admit they stuffed somthing up
