Page 1 of 2 12 LastLast
Results 1 to 12 of 18
    Mar 2011
    granville
    jdm front dc2
    which oil to use for my d16
    hey guys im due for a service for my ek1 and i was wondering which oil would be best,my engine has done 204xxx kms i thinking about filling it up with castrol edge sport 5w-30. would this be a good choice or is there other oils more suitable for an engine thats been clocked 204xxx
    cheers
    Oct 2006
    Hunter Valley NSW
    lownslowsedan
    Use a mineral oil. If it uses oil/blows smoke go 20w50
    If it doesn't then use 10w40
    to see all of my build, checkout
    Aug 2007
    brisbane
    97 integra
    i use 10w 40 castrol magnatec when i had my ek1
    Mar 2011
    granville
    jdm front dc2
    how was castrol magnatec?
    i use magnatec on my d series also.
    doesnt burn as quick.
    Nov 2010
    Some where in the world
    b18c2+T Ej8
    Run it with out oil, They asked this question more than million time in here. The older the engine the thicker oil you use.
    Whenever the car start burning oils use even thicker oil.
    200kkm+ use 10w40 , or 15w40 if the engine is burning oil use 20w50.
    Mar 2011
    granville
    jdm front dc2
    oh my bad thanks man
  8. #8
    Apr 2010
    S.E. Melbourne
    Del Sol
    if u dont mind paying for castrol edge, i wud recommend motul 8100
    similar price, better performance on my B16
  9. #9
    Sep 2008
    Melbourne
    Kermit K20A
    i would be using at least a 15W on an engine with 200+ km on the clock. have seen to many cars come in to work that have been running 5W or 10W on high km engines and they spin bearings because the oil is too thin and does not lubricate correctly, so just because it's not burning oil, does not mean it is helping your engine
    Kermit EGK20A
    Winton: 1:35.08
    Wakefield: 1:08.8
  10. #10
    Moderator Array
    Apr 2008
    Melbourne
    '90 EF8/'94 EH9
    I would just use Castrol Magnatec also. Been using it for the last 40,000 KM's no problem.
  11. #11
    Oct 2006
    Hunter Valley NSW
    lownslowsedan
    Quote Originally Posted by dc292177917 View Post
    why would you use motul in an engine that was designed with economy in mind?
    pointless.
    I run a homemade concoction of honey, canola oil, and smiths salt and vinegar chips, the crinkle cut ones, as the straight cut ones dont work properly.
  12. #12
    Dec 2007
    melbourne
    eg5 si
    because the sticker clearly says its a high performance engine on the ek d16s :P
    but yea on a serious note.. dont use anything under 10... also see if your engine is blowing smoke or leaking alot of oil.. if its doing any of or both of those then best to use a 20 to begin with..
    dont bother with motul with such a high km engine.
