Page 1 of 2 12 LastLast
Results 1 to 12 of 16
    Sep 2010
    westside
    da9
    JDM tilt plate relocator
    back in my country JDM tilt plates are very popular . I was wondering is it legal to have tilt plates here in victoria. wanna put that JDM filo flava on the car lol
    you mean the number plate?
    find me one.....
    Welcome abourd ozhonda.
    Oct 2004
    www.alibaba.com
    porsche boxster
    Has to be visible at vertical 45 degrees so overhead cameras can see it
    http://www.austlii.edu.au/au/legis/v...eg/rsr2009309/
    Code:
    (1) The registered operator of a vehicle must ensure each number plate issued
    by the Corporation for the vehicle is permanently affixed to the vehicle so
    that, when the vehicle is on level ground-
    (a) the number plate is at all times in an upright position parallel to
    the vehicle's axles; and
    (b) the number plate is at all times not more than 1×3 metres above ground
    level; and
    (c) for a motor cycle, the centre of the number plate is at all times at
    least 30 centimetres above ground level; and
    (d) the number or letters, or both, on the number plate are clearly
    visible from a distance of 20 metres from the number plate at any
    point within the space produced by a horizontal arc of 90 degrees and
    a vertical arc of 45 degrees, as indicated by the shaded areas in
    figures 5 and 6; and
    (e) any cover on the number plate-
    (i) is clear, clean, untinted and flat over its entire surface; and
    (ii) has no reflective or other characteristics that would prevent the
    successful operation of a device approved for use under a law relating
    to the detection of traffic offences; and
    (f) for a motor vehicle other than a motor cycle, one number plate is
    affixed to the front of the vehicle and another to its rear; and
    (g) for a motor cycle or trailer, the number plate is affixed to the rear
    of the motor cycle or trailer.
    (2) The requirements in subregulations (1)(a) to (d) do not apply to a number
    plate for a vehicle if-
    (a) due to the construction of the vehicle it is not practicable to comply
    with the requirements; and
    (b) the number plate is affixed in a way that complies as far as
    practicable with the requirements.
    (3) If a vehicle is fitted with a bicycle carrier, the number plate required
    under subregulation (1)(f) to be fitted to the rear of the vehicle may instead
    be securely affixed to the bicycle carrier.
    Sep 2010
    westside
    da9
    therefore it is legal as long as it is on a 45 degree angle?
    Quote Originally Posted by maaaaark View Post
    The information you need has been posted.
    LOL
    unless you need reassurance?
    PS, if you find one, please PM me.
    Sep 2010
    westside
    da9
    Quote Originally Posted by Bludger View Post
    LOL
    LOL i wanna be 100% sure.. hey man there are a lot of tilt plates on ebay US just type in tilt plate relocator
    Oct 2006
    Hunter Valley NSW
    lownslowsedan
    sigh.
    your number plate is vertical right now. 90 degress to the horizontal. Now, at 45degrees to the horizontal, draw an imaginary line. Your number plate must be visible at any point from horizontal to this point, from any distance away.
    if you tilt it at 45degrees towards the ground, its not gonna be visible is it?
    do you understand, or would you like a picture?
    to see all of my build, checkout
  8. #8
  9. #9
    Oct 2004
    www.alibaba.com
    porsche boxster
    hes in Victoria good sir but good info
  10. #10
    Jan 2005
    Toronto, Ontario
    Corolla Spec S
    Quote Originally Posted by trism View Post
    sigh.
    i think he would like a picture
    peteju captures, like us on facebook..
  11. #11
    Oct 2004
    www.alibaba.com
    porsche boxster
  12. #12
    Sep 2010
    westside
    da9
    thanks
