Just curious, Are handbreak cables interchangeable between the civics/integras? for example, 5 stud conversion onto an eg, are the hand brake cables interchangeable ? thanks
yes i have used eg6/dc2r and ek9 lines before
BIG JDM TYPE R PARTS FOR SALEhttp://www.ozhonda.com/forum/showthread.php?t=117546
how about eg4 to 5 stud or 96 spec or just disc brake etc,
yes they are interchangeable but you might find that dc2r/dc2 lines may fall a bit short, but it's doable.
will drum brake e break cable from a eg work with a dc2r 96 spec rear disc setup?
it's just the cable, don't think if its drum to disc it makes a difference, not too sure edit: well it's different.
nope drum cable is different to disc.
OEM parts whore
Drums handbrake cable is different to disc handbrake cable.
