Page 4 of 4 FirstFirst 1234
Results 37 to 41 of 41
  1. #37
    Nov 2004
    Syd
    a k swap isnt a k swap unless you use eg subframe.
    if you want clearance. use the ekk2 mounts and eg subframe.
  2. #38
    Quote Originally Posted by IV73CI View Post
    Lol.. My bad juz got off the plane.. Lol
    I cant bruz,
    I got em1 with abs.. Cant delete ot or i wont pass engineering cert.
    Got the same set up in my car running ekk2 mounts dc2r subframe with k24 and there isn't any problems with abs, might have to modify the headers to clear the abs depending on the headers you run, but in can be done. The power steering pump will just clear the surface material of the bonnet with the frame guttered but will touch on hard launches.
    The skunk2 kswap headers clear the abs with no mods
  3. #39
    Nov 2010
    inb4yursorryass
    Quote Originally Posted by EM1 View Post
    Do i need to change over the steering rack? Or just the subframe & lcas?
  4. #40
    Lower the engine mounts and put spacers in between. Make sure your bolts are nice and long.
  5. #41
    I used a complete dc2r sub frame with rack and control arms.
    If you want to get it engineered you would have to exhaust wrap the headers or make a heat shield for the abs unit. Heat wrapping the headers would be probably be an easier option.
