Page 1 of 2 12 LastLast
Results 1 to 12 of 16
    May 2010
    Newcastle
    Honda Integra Type R JDM
    dc2 not starting fuel pump not priming. ( ECU RELATED )
    ok, so for the past few months my integra's fuel pumps has been intermittently not priming, the other night when i really needed the car was the final straw!
    so tonight i decided to hook up a switch to the pump because i couldnt work out why it wasnt priming.
    so, i have fuel ( checked the fuel rail, ( fuel pissed out errywhere! ) fuel pump is priming!
    and i have spark. ( screwdriver in end of lead, close to earth.. )
    and the car wont start at all.
    the car doesnt have an alarm, recently removed.
    UPDATE! so i swapped over to the factory ecu ( current one is a hondata) and bam fuel pump primes.... and the car starts... i dare not drive the car on the factory ecu ( boosted engine ) i just dont understand. usually things like that arnt a slow break down. usually an electrical component " from my understanding" in an ecu simply just fails...
    the only thing i havnt really checked is for an injector pulse.
    but i just cant understand why that would suddenly happen.
    jdmEG5: Will u take 2 ounces of weed +$500 your way? I'm not kidding.
    Speed is a matter of money... How fast can you AFFORD to go?
    May 2010
    Newcastle
    also just changed fuel pump relay to a known working one... still not working,
    also tested earth strap on thermostat housing
    also tested main earth strap on gearbox to chassis
    Mar 2007
    www.letusdrive.com.au
    D15B7 YOOOOOO!
    you can always just test earth via the chassis instead of ground.
    a faulty fuel pump can cause a relay to fault,
    a faulty relay can failt the fuel pump.
    you also mentioned "ok, so for the past few months my integra's fuel pumps has been intermittently not priming", if the pump fails to prime at times have you tried getting a 2nd hand one from a wreck etc and testing it?
    have you checked all your earthing points, motor to chassis, battery to chassis etc?
    did you do any sort of timing related work on your car lately?
    Check out my build thread EGB16T. http://www.ozhonda.com/forum/showthr...build../page14
    Check out my for sale thread constantly updated with b series/ eg parts!
    Wakefield Honda Nationals First Timer : na-118 EG b16 1:16.4900
    May 2010
    Newcastle
    tried all that, the fuel pump is a new walbro... but yes, i swapped for factory, checked the loom for power nothing.. had earth but no power....
    pretty sure the ecu is dead... not sure how or why. but i just put in the factory ecu and the pump primed... and the car started.
    May 2010
    S.E Melb
    EG5 & SF5
    where did u get the hondata from? maybe contact the seller or something?
    **** i would be angry if that was my hondata
    -=[BLACK Dc2]=-
    EXE TRACK DAY 2014 PB 1:37.0
    May 2010
    Newcastle
    I bought it off another member about 2 years ago.
    I opened the ecu up and it doesnt "seem" to have any burn marks.
    I've contacted Hondata, and asked them about it. Hopefully they can shed some light to what's going on
    Sad day is sad.... Seems to be one thing after another lately
    Sep 2007
    Australia
    your mum
    What voltage should the fuel pump be running?
  8. #8
    Mar 2007
    D15B7 YOOOOOO!
    Fake walbro pumps are also out there.!
    Use amp meter and check amp draw. Could be drawing from ecu
  9. #9
    May 2010
    Newcastle
    Yeah but the way I look at it, everything like that is fine because when I put in standard ecu everything works perfectly
  10. #10
    Problem is the ecu, if hondata s200 is blinking means you have problem
    It should be solid.
  11. #11
    May 2010
    Newcastle
    ok so i pulled the blue box apart, gave it a wipe down,
    and then i pulled ecu apart and did the same.
    put ecu back in. car now drives. and everything is fine.
  12. #12
    Mar 2007
    D15B7 YOOOOOO!
    measure twice cut once,
    the way you look at it measure once cut twice
    Quote Originally Posted by Alexplicit View Post
