+ Reply to Thread
Page 1 of 3 1 2 3 LastLast
Results 1 to 12 of 28
    My mates project, EG/ G22 frankenstine turbo.
    Here it's the original thread I started in the civic section...
    http://www.ozhonda.com/forum/showthr...22-Frankie-EG4
    Here is the specs on the motor etc, for those who couldn't be bothered reading the other thread.....
    F22A1 Block
    Custom Aluminium 5.5Qty Sump
    Crankshaft Re-Grind
    Eagle Rods
    CP Pistons 85.5mm
    Block Guard
    2mm Copper Head Gasket
    H22A4 Head
    Port and Polish
    Ferrea 6000 Series Valve Seats
    Ferrea Valve Locks
    Ferrea Valve Stem Seals
    Ferrea Stainless 6000 Series Valves
    Ferrea 6000 Series Beehive Valve Springs
    Ferrea 6000 Series Beehive Titanium Retainers
    Ferrea Roller Rockers
    Ferrea Roller Camshafts
    All New Bearings Through Out
    Billet Cam Seal
    Unorthodox Light Weight Crank Pulley
    OBX Lightweight Pulley Kit
    OBX High Volume Fuel Rail
    Thermal Intake Manifold Gasket
    Skunk2 Pro Intake Manifold
    Skunk2 Pro 70mm Throttle Body
    Skunk2 Pro Titanium Cam Gears
    Tial 46mm Wastegate
    GT 35/40r Garret Turbo
    Vision 10.3mm Spark Plug Leads
    NGK Platinium Spark Plugs
    Jun Spark Plug Cover
    Vision External Coil
    Walbro 255Lb Fuel Pump
    Fuel Regulator
    JDM High Volume Fuel Filter
    GReddy Oil Filter
    NRG Engine Damper
    STR Dipstick
    Hasport Engine Mounts with 70A Bushings
    HKS SSQV BOV
    OBX 1.5 LSD
    Extreme Carbon Cushion Button Clutch
    Fidanza 8Lb Flywheel .
    And this is where he is with it now....
    When words fail, Vtec speaks....!
    G22! Now THAT is awesome.
    Don't think i've heard of one in Australia before?!
    Brilliant combo' though.. Looks mint.
    It's not 4x4 status, think of it as "Winter Mode".
    Member EKVTIR-T has a reputation beyond repute EKVTIR-T has a reputation beyond repute EKVTIR-T has a reputation beyond repute EKVTIR-T has a reputation beyond repute EKVTIR-T has a reputation beyond repute EKVTIR-T has a reputation beyond repute EKVTIR-T has a reputation beyond repute EKVTIR-T has a reputation beyond repute EKVTIR-T has a reputation beyond repute EKVTIR-T has a reputation beyond repute EKVTIR-T has a reputation beyond repute
    Oct 2004
    www.alibaba.com
    rebirthed_ek9
    Cool project
    Why front wheel drive?
    Cause Civics are front wheel drive....!
    He's considered the conversion though....!
    Member jdm18c seems to know what they're on about jdm18c seems to know what they're on about
    Feb 2009
    kings langly
    jdm b16a civic
    thats insane!!!!!!!!!!!!!!!!
    Banned dc2r_fAn seems to know what they're on about dc2r_fAn seems to know what they're on about dc2r_fAn seems to know what they're on about
    Mar 2008
    Sydney
    Nothing... Yet!!!11!!
    looks fantastic.... what power figures is that making?
    250+atw?
    He's expecting an easy and relyable 400fwhp @ around 15lb......
    Added engine shipping list to first post.....
  8. #8
    Quote Originally Posted by ThePacman View Post
    Should be well possible!
    I know of a few G22A's making 500+ WHP with under 20psi.
  9. #9
    Yeah, it's a reasonable figure. I'm just worried that it will be a dog for him to drive.
    It'll be lucky to idle under 2000rpm. And this is supposed to be his daily...
  10. #10
    I re-read the shopping list.
    What cc injectors?
    What compression? Hopefully standard ratio..
    I can't see any reason this won't achieve factory idle.
  11. #11
    He's using RC 750cc injectors, not sure what his c/r is.
    But with the roller cam set up, no Vtec, those cams are HUGE....!
    It wil idle like a bitch....!
  12. #12
    noooo! no vtec
+ Reply to Thread
