+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 12 of 18
Thread: clutch pedal
    Member viinnh is a splendid one to behold viinnh is a splendid one to behold viinnh is a splendid one to behold viinnh is a splendid one to behold viinnh is a splendid one to behold viinnh is a splendid one to behold viinnh is a splendid one to behold
    May 2010
    Cabramatta,NSW
    Mazda 6 / EK
    clutch pedal
    help me please.
    I changed my master and slave for clutch today. I bleed the lines already to the point where it pisses out fluid from the nipple like water flowing outta a tap. the clutch pedal is like normal when i press it in and keep on pumping it rapidly its really hard like how it should be (heavy duty).
    But when i stop for about 2 seconds it looses pressure. would you know what is wrong ?? and if i pump it rapidly again it goes to normal. with in 2 seconds with out pumping it, it looses pressure
    If it's not leaking fluid then you have air in the master cylinder or lines
    May 2010
    Cabramatta,NSW
    Mazda 6 / EK
    ive bled it heaps of times already went through 2 bottles of fluids
    btw when theres no pressure in the pedal. its just like having no fluid it drops down and doesnt come back up. i pull it back up and start pumping it gets back to normal
    Banned GU357 has an exceptional understanding GU357 has an exceptional understanding GU357 has an exceptional understanding GU357 has an exceptional understanding GU357 has an exceptional understanding GU357 has an exceptional understanding GU357 has an exceptional understanding GU357 has an exceptional understanding GU357 has an exceptional understanding GU357 has an exceptional understanding GU357 has an exceptional understanding
    Apr 2011
    Perth
    B16EG-GD3-DC2
    most likely a leak, keep an eye out for fluid, or it might be internally and the fluid is filling up inside the master?
    Member SLOBRO is a glorious beacon of light SLOBRO is a glorious beacon of light SLOBRO is a glorious beacon of light SLOBRO is a glorious beacon of light SLOBRO is a glorious beacon of light SLOBRO is a glorious beacon of light
    Oct 2010
    Sydney
    Laser,B16EF,DC2
    can you explain how you bled it??
    May 2010
    Cabramatta,NSW
    Mazda 6 / EK
    Quote Originally Posted by GU357 View Post
    nah looked everywhere no fluid coming out
    took apart the master had a tiny bit of fluid inside not much, like a few drips
    Quote Originally Posted by SLOBRO View Post
    step in clutch. release nipple closed it, pump pedal a few times put pedal to the floor release nipple etc etc till it went hard from pumping it but then if i dont pump it it goes down
    Oct 2010
    Sydney
    Laser,B16EF,DC2
    ok try this leave the nipple open till it starts dripping fast then close it then check it
  8. #8
    May 2010
    Cabramatta,NSW
    Mazda 6 / EK
    i actually did try that in the arvo. i left it open and got someone to pump the pedal while i wait for fluid to go down so i can top it up
    once itstarted pissing i told them to put the foot down and i closed the nipple.
    results same thing
  9. #9
    Oct 2010
    Sydney
    Laser,B16EF,DC2
    there you go you can't pump it while the nipple is open man it won't work like that
    + what i meant was just leave the nipple open dont pump the pedal leave it open and let it drip then close it
    and did u run out of fluid when your mate was pumping the pedal? if so you might have stuffed your new Master cylinder
  10. #10
  11. #11
    Mate try this
    Run a clear or somewhat translucent tube from the nipple to a bottle half filled with fresh brake fluid- make sure the end is BELOW the surface.
    Open the nipple with a 8mm spanner , open the clutch reservoir cap and start pumping the clutch pedal by hand. Get
    Your mate to monitor the reservoir and top up - keep pumping until a steady stream of fresh fluid fills the bottle. Tighten nipple, remove tube and top up the reservoir if need be. That should be it.
    DIY IT
  12. #12
    May 2010
    Cabramatta,NSW
    Mazda 6 / EK
    nah man i tried that method after bleeeding it the normal way heaps of times
    no my fluild was always full hardly went down
    Quote Originally Posted by bennjamin View Post
    Mate try this
    i have tried this as well same thing
    guys after playing around with the clutch pedal this is what happens
    press the pedal down hard it will be hard like a normal HD clutch
    press the pedal down soft it would be like theres no fluid inside what so ever it just goes down and i have to pull it back up
