+ Reply to Thread
Results 1 to 8 of 8
    How does a LSD gearbox work?
    Could somebody please explain how a LSD gearbox works compared to a non LSD gearbox
    I know the basics but have never found out exactly how they work and i am sure there is a lot of people that dont know how they work
    Member 90LAN has much to be proud of 90LAN has much to be proud of 90LAN has much to be proud of 90LAN has much to be proud of 90LAN has much to be proud of 90LAN has much to be proud of 90LAN has much to be proud of 90LAN has much to be proud of
    Jul 2006
    JDM PARTS BRISBANE
    EURO LUX
    how does google work ?
    Banned GU357 has an exceptional understanding GU357 has an exceptional understanding GU357 has an exceptional understanding GU357 has an exceptional understanding GU357 has an exceptional understanding GU357 has an exceptional understanding GU357 has an exceptional understanding GU357 has an exceptional understanding GU357 has an exceptional understanding GU357 has an exceptional understanding GU357 has an exceptional understanding
    Apr 2011
    Perth
    B16EG-GD3-DC2
    since FWD use a transaxle that means the final drive is built in to the gearbox. A gearbox with an Ordinary Final drive will have what is called an Open Differential.
    Final Drives are often called Diffs or Differential where in fact the Differential of a Final Drive is the gear set between the drive shaft outputs which allow both drive shafts connected to the wheels to rotate at different speeds while a vehicle is cornering in order to maintain vehicle stability and drivability. Positive drive traction is only applied to one wheel.
    A Limited Slip Differential will have clutches or some kind of locking mechanism between the two driveshaft outputs that will lock or provide more resistance between the differential outputs to provide positive drive traction to both drive wheels simultaneously.
    Honda's ATTS introduced in the 1997 VTiR Prelude is an electronically controlled type of differential where in fact the ATTS unit will actually speed up the inside wheel when cornering to assist in reducing under steer during higher speed cornering. ATTS housing consists of hydraulic pump and clutches which are controlled by an Electronic Control Unit.
    Honda's SH-AWD System is a more advanced ATTS type of system that can perform ATTS type of functionality on the front and rear wheel and also control power between the front and rear wheels to assist in vehicle stability and control.
    These are just brief descriptions of the above technologies, someone can provide more in-depth descriptions if they like as there are many types of LSD Types. The Gearbox it self will be the same its just the final drive that will have the LSD or not as part of its differential.
    Thanks sums up my question
    Quote Originally Posted by 90LAN View Post
    Don't know dude you should google that
    Quote Originally Posted by babybashjnr View Post
    I googled your exact question and found many answers.
    DIY IT
    Ok thanks...
