+ Reply to Thread
Page 2 of 2 FirstFirst 1 2
Results 13 to 17 of 17
    ^^main relay..
    Had same symptoms on an old bseries conversion..
    Turns out the main relay was fcked and locked up/burnt coil.
    Member DriftKnightX has made a few knowledgable posts
    May 2009
    Inala!
    91' EG BREEZE!
    had the same problem here, main relay problems are common sadly...
    Member FAITHLESS has much to be proud of FAITHLESS has much to be proud of FAITHLESS has much to be proud of FAITHLESS has much to be proud of FAITHLESS has much to be proud of FAITHLESS has much to be proud of FAITHLESS has much to be proud of FAITHLESS has much to be proud of FAITHLESS has much to be proud of
    Jun 2011
    Coffs Harbour
    CivInteJazPreAc
    The problem turn out to be the thermostat ground. It wasn't torqued down tight enough.
    I however have a new problem. I only have spark when turning the ignition on and off at the plug that the distributor rotor has stopped on.
    I have no spark when turning the engine over.
    I intend to do a full check on the coil and ICM but it's very difficult to remove the bolt that holds the rotor due to the splash shield.
    Is there anything other than the distributor, coil and ICM that might be causing this problem?
  4. #16
    check power to the coil whilst cranking even hard wire it to the battery if this solves the issue trace from the ignition switch to the fusebox and poor earth is a common casue
    View Tag Cloud
  5. #17
    Jun 2011
    Coffs Harbour
    CivInteJazPreAc
    Quote Originally Posted by SU-WOOP View Post
    Thanks alot buddy will do.
+ Reply to Thread
