Anyone know where to get Honda premix coolant from?
As said above , i'm looking for honda coolant.
Any help with this would be appreciated.
Cheers
Stage 1 FI engine,SOS supercharged,Laminova intercooler,Liquid to air intercooler,ARC titanium exhaust,DC headers,High flow cats,AEM EMS,Short ratio gearbox,KW V3 coilover suspension
honda spare parts at your local stealership
snapping 2nd..
Hondawreck on Westall Rd.
Stocky CL9 - 1:17.2
Cheers,
I will check them out.
Originally Posted by funkynsx
Cheers,
did you check them out? did you find out how much?
I bought my coolant from Honda.
I got it for $46 for a five ltr container because i bought 20 ltr.
That was the cheapest i found.
y not just use nulon pre mix?
Fear of corroding the water pump. Honda coolant also lasts 100,000km, so the extra cost doesn't add up to much in the long run.
Stocky CL9 - 1:17.2
I'm using what my engine builder and honda has recommended.
I'm sure there are other brands that could be used but i'm sticking with honda premix.
I changed the nulon premix in my old accord after 70g km. Look the same as brand new. Regretted waisting my time after i saw how clean it was! use it in all my cars now!
I would be more concerned with the state of your thermostat,water pump and radiator rather than whether the coolant is clean after 70k km's.
Honda premix has organic inhibiters specially designed for alluminium engines.
I dont mind paying a few extra bucks to get the genuine product.
yes the honda coolants are good but you need to read up on what the main stream coolants are made from before you dismiss them ie the nulon coolant exceeds the specs of the honda coolant, this brand is renouned for being top of the range ,green two years or red for 5 years .
ive used this brand now for 5 years in all my cars and its gets a big tick for all there products ,read there specs at there web site you will be surprised,i was.
also pump and thremostat are not the main problem aluminium head rotting is and gaskets ,hoses
