+ Reply to Thread
Results 1 to 6 of 6
    [CL9] Audio Fuse
    Hi guys,
    As part of diagnosing a battery drain issue I'm having with my standard CL9 lux I decided to eliminate the audio system from the equation by removing the fuse. It wasn't labelled specifically on the interior fuse panel so I consulted the manual which lists "Audio" as being fuse number 5 from the bottom left hand corner.
    I promptly removed this but then to my surprise the stereo turned on and is running as normal. No error/warning lights on the dash are appearing and all the accessories seem to still being working.
    Is this normal - is there another fuse I'm missing here?
    Member -[NoS]- has made a few knowledgable posts
    May 2004
    Melbourne
    '07 CL9 lux
    on mine... its number 6... its connected with the ceiling lights... 10 amp fuse
    i trip it sometimes coz ive got a double din below and the factory headunit is still connected...
    i think its sharing the ground/power or something... havent gotten around to fix it...
    For Sale:
    95' Civic Sedan VTI 165,000ks
    5zigen GN+ (17 x 7.5 +43 4 x 100) with tyres
    07' CL9 Foglight covers Arctic Blue pm me!
    Weird that it's labelled as number 5 in the manual, so maybe it is sharing load between the two circuits (i.e. it's own on number 5 and then the ceiling dome on number 6). Still confused how it can keep working if number 5 is pulled.
    Here is the manual showing number 5 is audio:
    Any chance someone can pull the number 5 fuse on theirs and see if the audio system still comes on?
    I noticed my 20 amp audio fuse had some black track marks on the blades of the fuse, possibly pointing to some excess current load there.
    Member roony seems to know what they're on about roony seems to know what they're on about
    May 2010
    Melbourne
    Honda Accord Eu
    I tested it. Pulled 5 and everything still working. Then pulled 6 by itself and audio along with the interior lights stopped working. So i guess just pull 6.
    Quote Originally Posted by roony View Post
    Cheers, thanks for that mate. It's reassuring to me that at least nothing fishy is going on with regards to the wiring in the car (which is what I suspected seeing that it's totally stock one owner car).
    May 2004
    Melbourne
    '07 CL9 lux
    there you go.. 6 is the winner... :P
    For Sale:
