+ Reply to Thread
Results 1 to 9 of 9
    EK9 Muffler Straight bolt on to Xforce system
    Hi Guys,
    My EG is currently running an Xforce cannon exhaust system and was wondering if an EK9 muffler would bolt straight onto the Xforce system?
    And also if the EK9 Muffler would need new hangers?
    Sorry for the nooby question!
    Cheers guys!
    Any exhaust shop could make it fit and add some new hangers but I don't recomend it if the exhaust inlet is bigger than the exhaust you have on it now.
    Quote Originally Posted by Renaissance_x View Post
    Ah alright cheers!, why dont you recommend it if one inlets bigger than the other?
    Should bolt on mate
    Quote Originally Posted by EGG5 View Post
    I'm confused are you fitting the oem exhaust piping to the xforce muffler? If so what are the diameter on both?
    VTEC Gets You Laid!!!!!
    Quote Originally Posted by rhys.l View Post
    Should bolt on mate
    Alright cheers, ill give it a shot on the weekends!
    Quote Originally Posted by HondaTurboVtec View Post
    OEM EK9 Muffler to Xforce piping
    Are they both same size or?
    Member Spoon SiRG has made a significant amount of informative posts Spoon SiRG has made a significant amount of informative posts Spoon SiRG has made a significant amount of informative posts
    Feb 2007
    Western Sydney
    DC2 & GE8
    NO it will not bolt on.
    The X force B-pipe uses a different flange. (flat)
    You will need to cut & weld an OEM EK9/ DC2R OEM B-pipe flange onto the X force B-pipe; or cut & weld an aftermarket flange onto the EK9 axleback; or just weld them together lol.
    The OEM hangers just need to be slightly bent in to fit your EG Hatch nicely.
    Might as well cut & shorten the tip to sit flush with the bumper. (Will stick out a bit)
    Member mcOZ Knows a bit of info here and there
    Mar 2012
    S.E Melbourne
    92' EG5
    Quote Originally Posted by Spoon SiRG View Post
    ^+1
    I just installed my OEM EK9 muffler onto my X force system, just need to do what Spoon SiRG said and it will fit nicely.
+ Reply to Thread
